A
airshot
replied to the thread
Oil 4 stroke Mercury 115hp
Just look around at all the high performance 4 stroke engines, dragsters, nascar, Indy type...etc...these all run at high rpm, and they...
Tuesday at 10:43 AM
J
Jeff J
Trailer tires.
I was not speaking of the inside versus outside corners. It’s normal for the inside corners to wear first. I was responding to an...
Tuesday at 10:43 AM
redneck joe
reacted to
MikeSchinlaub's post
in the thread
Boats from work.
with
Like
More truck pics. Some damage to the inner support panels too, as well as the hood seperating from them. Everything is just epoxied...
Tuesday at 10:42 AM
A
airshot
reacted to
racerone's post
in the thread
with
Like
Automotive engines are rarely asked to perform at full throttle / maximum power output for long periods of time.----The outboard is also...
Tuesday at 10:37 AM
M
MikeSchinlaub
Boats from work.
Tuesday at 10:28 AM
S
SeaRayboater95
reacted to
flashback's post
in the thread
Coil wire install
with
Like
what "book" It's been my experience that it needs to be clean. the dielectric grease would be fine.
Tuesday at 10:24 AM
S
SeaRayboater95
reacted to
Fun Times's post
in the thread
Coil wire install
with
Like
https://www.ebay.com/itm/404968941657#:~:text=This%2520Quicksilver%2520Marine%2520Insulating%2520Compound%2520seals%252C%2520waterproofs%...
Tuesday at 10:22 AM
M
MikeSchinlaub
1983 Blue Fin 16’ Resto
Windshields often dont even have gaskets on the mating surface. You could put a bead of silicone down if you want.
Tuesday at 10:18 AM
jimmbo
1978 Johnson 140hp running rough. Need advice
Smaller Bore? That will cost top end Hp, but will help Hole Shot
Tuesday at 10:07 AM
Fun Times
Coil wire install
Tuesday at 9:47 AM
S
SeaRayboater95
Coil wire install
Mercruiser #18 Service Manual. I usually use Dielectric grease as well. When I removed this wire from the coil, it was glued in there...
Tuesday at 9:42 AM
flashback
Coil wire install
Tuesday at 9:34 AM
S
SeaRayboater95
Coil wire install
Thanks Mike for your response. The manual calls for "1/2 oz insulating compound". Not sure what that is.
Tuesday at 9:04 AM
nola mike
Coil wire install
I would normally go with Dielectric grease in this case, but not sure what the manual specifies
Tuesday at 8:51 AM
nola mike
Trailer tires.
Every car I've owned had much greater inner wear than outer. Guessing anything reasonably sporty runs with a good amount of negative camber.
Tuesday at 8:47 AM
