M
Mc Tool
replied to the thread
Oil 4 stroke Mercury 115hp
I like the penrite hpr as it has the "extra 10 " which does help maintain viscosity when hot. I started using it as when I got my Guzzi...
Tuesday at 1:04 PM
M
Mc Tool
reacted to
airshot's post
in the thread
with
Like
Just look around at all the high performance 4 stroke engines, dragsters, nascar, Indy type...etc...these all run at high rpm, and they...
Tuesday at 12:56 PM
M
Mc Tool
reacted to
racerone's post
in the thread
with
Like
Automotive engines are rarely asked to perform at full throttle / maximum power output for long periods of time.----The outboard is also...
Tuesday at 12:55 PM
M
Mc Tool
reacted to
Lou C's post
in the thread
with
Like
When evaluating oils for marine use, one thing I will notice is this: after running the boat up on plane for a while, slow down, let the...
Tuesday at 12:55 PM
M
MikeSchinlaub
Boats from work.
It would probably be cheaper to get a used one and have it sprayed to match.
Tuesday at 12:46 PM
M
MikeSchinlaub
Boats from work.
No! I refuse to accept praise on the grounds that I found ANOTHER problem. I think the cardboard sagged out, and the whole thing tilts...
Tuesday at 12:38 PM
M
MikeSchinlaub
reacted to
aspeck's post
in the thread
Boats from work.
with
Like
Mike, if you were closer I would get you to fix the bumper of my wife's Acadia. Some jerk backed into it at Walmart we believe and left...
Tuesday at 12:36 PM
M
MikeSchinlaub
reacted to
DeepCMark58A's post
in the thread
Boats from work.
with
Like
Mike you are not just an artist, holy crap.I enjoy the posts.
Tuesday at 12:33 PM
jimmbo
1978 Johnson 140hp running rough. Need advice
Shows there was something wrong with old Carbs, but if they had been functioning properly, they would have delivered even better top end...
Tuesday at 12:32 PM
flashback
reacted to
Fun Times's post
in the thread
Coil wire install
with
Like
https://www.ebay.com/itm/404968941657#:~:text=This%2520Quicksilver%2520Marine%2520Insulating%2520Compound%2520seals%252C%2520waterproofs%...
Tuesday at 12:29 PM
rothfm
Painting factory diamond pattern non-skid.
Thank you....will have to do a bit of experimentation. What i see is the tops of the diamond pyramids wore through leaving an edge...but...
Tuesday at 12:18 PM
B
Bman2895
Actually helped both. But helped the hole shot tremendously. Idle was smooth and it no longer has a lean sneeze.
Tuesday at 12:14 PM
BWR1953
Nobody fishing?
Nice! (y)
Tuesday at 12:05 PM
aspeck
Boats from work.
Tuesday at 11:52 AM
aspeck
Nobody fishing?
Was the first one your bait for the second one? Nice bass you got there, Igaytan!
Tuesday at 11:50 AM
