M
Mc Tool
replied to the thread
Oil 4 stroke Mercury 115hp
Yeah but a nitro drag car is producing 1300hp/litre ....on nitromethane , its not a fuel burn, its a detonation harsh enough to...
Yesterday at 12:46 AM
M
Mc Tool
35hp choke linkage hookup?
Doesnt it fit into the semicircular recess to the left of the choke pivot shaft . Then tighten the pivot nut on other end of spring with...
Tuesday at 11:42 PM
M
Mc Tool
Cracked bearing carrier, run or replace?
I love that feeling of success when something that has previously given you grief just clicks into place . Result 🍺👍
Tuesday at 11:16 PM
M
Mc Tool
reacted to
aidanmurphy's post
in the thread
with
Like
Okay got it in easily today. Just had to mess with the shift cam position and keep pushing / turning the prop shaft so that the spring...
Tuesday at 11:14 PM
roscoe
Hot water heater
As far as on going cost for using the recirculating pump, I have no idea. For me, the cost of the pump, over 60' of plumbing, and...
Tuesday at 10:20 PM
Lou C
Exhaust manifold discovery?
for some reason that's a Vortec 4.3 issue only, the pre-Vortec didn't have that issue. Just pulling the bottom end of the big hose on...
Tuesday at 10:11 PM
A
aidanmurphy
Tuesday at 8:15 PM
D
DeepCMark58A
Inspecting a 2007 Mako 284 - what to look for?
Run away
Tuesday at 8:02 PM
S
saltchuckmatt
reacted to
Chuck4741444's post
in the thread
Mounting bracket for j200
with
Like
The top bolts are 3/8 to close that 3/16 each side. I built a rack to hold the old motor today, I believe the bolts with have enough...
Tuesday at 7:56 PM
dingbat
MS Office alternative
There are a number of on-line sellers that sell keys. The older the version of software the cheaper the key. Bought Office Pro 2021 for $25
Tuesday at 7:48 PM
A
ALLONA
Did a thorough inspection, not good. Transom is loose. Will have a contractor take a look tomorrow before walking away. If it can be...
Tuesday at 7:45 PM
C
Chuck4741444
Tuesday at 7:34 PM
jimmbo
Perhaps around the Choke Control Shaft #24.
Tuesday at 7:28 PM
S
SeanT7
reacted to
nola mike's post
in the thread
Mercruiser 165 shifter cable thread repair
with
Like
So was the boot torn, or just the outer jacket of the cable? If just the cable jacket, that wouldn't be the source of the leak. Boot for...
Tuesday at 6:53 PM
S
SeanT7
reacted to
Bondo's post
in the thread
with
Like
Ayuh,.... Welcome Aboard,..... It's 1/4" pipe thread, straight, non-tapered,....
Tuesday at 6:53 PM
