  • C
    Chris1956 replied to the thread 35hp choke linkage hookup?.
    The choke linkages were mostly the same on the inline motors of that vintage. I think the stud that holds the plastic grating also...
  • C
    Chris1956 replied to the thread Question on cap removal.
    Gee, put the boat back on the trailer. Build two "hangmans scaffolds" to support the cap. Use 4X4 posts and double 2x8 for the...
  • B
    No idea. I went through those carbs several times. Honestly? Those carbs weren't supplying enough fuel on the idle/transition...
  • C
    kind of curious what can go wrong with a carb other than expendable parts the rest is just holes to clean out and mecanical links.
  • J
    Jeff J replied to the thread No Vin for Trailer.
    That looks almost identical to my trailer. I wonder if it was made by Bear too?
  • J
    I wouldn’t think list weight for the boat would be very accurate (fuel, oil, water, grime, assorted equipment/tools and toys). If the...
  • A
    If you know where the tank is located, start looking for a small hatch or cover. Didn't say it would be out in the open and easy to get...
  • J
    Jeff J replied to the thread MS Office alternative.
    I think if I was that hard on laptops I would just buy a Toughbook. Mine almost never leaves the office. Mine will not run without...
  • W
    I wouldn't know where to even begin doing that. I didn't think a strip pit would have such muck on the bottom to sink into. There is a...
  • B
    Well I'll say it seemed smoother on the top end. But these like i say have some float issues? Sometimes you'll hear the rpm bog and...
  • G
    GLE3 posted the thread No Vin for Trailer in Sea Nymph Boats.
    Hi all, live in MI and bought a 19.5 GLS last summer from a guy that never had the trailer in his name. There is a sticker on the other...
  • Bt Doctur
    some heat and some "Free-All" will remove that screw
  • sad boater
    For anyone still following I have ordered the new amplifier, this time it's a more modern aftermarket part vs the original. This one...
  • L
    Lpgc replied to the thread MS Office alternative.
    I have run Office 2013 (mostly Word and Excel but had the full package) on W11, it worked but occassionally doing certain things (iIrc...
  • J
    The older versions are fine but at some point someone will send stuff that the old versions cannot open. Not to mention it needs to be...
