replied to the thread
No Vin for Trailer
They need the weight of the trailer for registration purposes. I would call the service department at the trailer manufacturer and they...
Yesterday at 10:52 AM
D
DeepCMark58A
Is there such a thing as peeing too hard?
If you do not see the telltale it defiantly effects the cooling.
D
DeepCMark58A
reacted to
airshot's post
in the thread
with
Like
If you can pee out a good 5' stream....you da man !!
Yesterday at 10:51 AM
D
DeepCMark58A
removing a pontoon off the trailer on land
Put the motor up pontoons do not draft that deep. Other people have boats on the water ask them what they do, somebody might have a home...
Yesterday at 10:49 AM
3
3rdtimesthecharm
reacted to
flashback's post
in the thread
with
Like
Drink lots of beer.!
Yesterday at 10:13 AM
flashback
Yesterday at 10:05 AM
C
35hp choke linkage hookup?
The choke linkages were mostly the same on the inline motors of that vintage. I think the stud that holds the plastic grating also...
Yesterday at 10:04 AM
C
Question on cap removal
Gee, put the boat back on the trailer. Build two "hangmans scaffolds" to support the cap. Use 4X4 posts and double 2x8 for the...
Yesterday at 9:57 AM
B
Bman2895
1978 Johnson 140hp running rough. Need advice
No idea. I went through those carbs several times. Honestly? Those carbs weren't supplying enough fuel on the idle/transition...
Yesterday at 9:53 AM
C
Crosbyman
kind of curious what can go wrong with a carb other than expendable parts the rest is just holes to clean out and mecanical links.
Yesterday at 9:40 AM
J
Jeff J
No Vin for Trailer
That looks almost identical to my trailer. I wonder if it was made by Bear too?
Yesterday at 9:32 AM
J
Jeff J
No Vin for Trailer
I wouldn’t think list weight for the boat would be very accurate (fuel, oil, water, grime, assorted equipment/tools and toys). If the...
Yesterday at 9:25 AM
A
airshot
2008 305 Conquest fuel tank sending unit access
If you know where the tank is located, start looking for a small hatch or cover. Didn't say it would be out in the open and easy to get...
Yesterday at 9:22 AM
J
Jeff J
MS Office alternative
I think if I was that hard on laptops I would just buy a Toughbook. Mine almost never leaves the office. Mine will not run without...
Yesterday at 9:13 AM
W
warddog
I wouldn't know where to even begin doing that. I didn't think a strip pit would have such muck on the bottom to sink into. There is a...
Yesterday at 9:11 AM
