R
replied to the thread
Spark on only one cylinder- 1997 Evinrude 50HP BE50TLEUC
The charge coil on the timer base fires both cylinders.--And the sensor coil on the timer base fires both cylinders.
Yesterday at 5:13 PM
S
sbs_59
24v Battery Charging Options
It's a 115 hp Yamaha, not sure about output. From what I've gathered, the main engine wouldn't have long enough run times to utilize an...
Yesterday at 5:06 PM
S
SeanT7
reacted to
nola mike's post
in the thread
Mercruiser 165 shifter cable thread repair
with
Like
Yes, permatex aviation. Don't use silicone anywhere on a boat (mostly, maybe on trim).
Yesterday at 4:42 PM
J
JonBoat55
Alpha1Gen2 gear oil leak
I think I may have found the problem. Used my finger to gently feel first, used the screwdriver for the video. Upper oil seal kit and...
Yesterday at 4:37 PM
R
rhays001
posted the thread
Yamaha 115 oil tank alarm
in
Yamaha & Suzuki Outboards
I need some help with a yamaha 115 115TLRA It has a oil tank on motor and a reserve in the boat, Alarm sounds and goes in limp...
Yesterday at 4:16 PM
R
rogerlamb123
Which kicker mount to install?
If I cant get underneath the stern to provide a support what do you think about a mount like this where it also mounts to the rear of...
Yesterday at 4:06 PM
flashback
reacted to
Scott Danforth's post
in the thread
removing a pontoon off the trailer on land
with
Like
still dont know why the tractor isnt moving dirt
Yesterday at 3:43 PM
flashback
reacted to
DeepCMark58A's post
in the thread
with
Like
Wait you have a private pit big enough for a pontoon? build a ramp. Private pit with no regulations, build a ramp get some rip rap make...
flashback
reacted to
Mc Tool's post
in the thread
Is there such a thing as peeing too hard?
with
Like
I think its one of them things where you dont realise how bad things had got untill you fix it .......Im talking about the outboard 😆...
Yesterday at 3:41 PM
A
alvinkarlsson69
posted the thread
in
Johnson & Evinrude Outboards
Hey, I'm in dire need of some help! Background: My engine only revs to about 2500rpms (sometimes over, S.L.O.W is most likely not the...
Yesterday at 3:06 PM
L
Lpgc
MS Office alternative
I've got an old Toughbook too but the main reason I have that is because it runs XP and has the old (native) legacy serial and parallel...
Yesterday at 3:01 PM
L
Lpgc
reacted to
Jeff J's post
in the thread
with
Like
I think if I was that hard on laptops I would just buy a Toughbook. Mine almost never leaves the office. Mine will not run without...
Yesterday at 2:56 PM
nola mike
Yesterday at 2:43 PM
nola mike
reacted to
kenny nunez's post
in the thread
with
Like
To replace the bushing/seal you will need to replace the shift lever because the screw will not come out, you will need to break the...
Yesterday at 2:41 PM
nola mike
reacted to
Bt Doctur's post
in the thread
with
Like
I developed this repair https://www.clubsearay.com/threads/for-mercruiser-only-shift-cable-thread-repair.93826/
