roscoe
reacted to
Chris1956's post
in the thread
35hp choke linkage hookup?
with
Like
The choke linkages were mostly the same on the inline motors of that vintage. I think the stud that holds the plastic grating also...
Yesterday at 6:33 PM
R
replied to the thread
Spark on only one cylinder- 1997 Evinrude 50HP BE50TLEUC
Wrong assumption.
Yesterday at 5:50 PM
B
boscoe99
24v Battery Charging Options
115 two stroke or F115 four stroke?
Yesterday at 5:39 PM
S
SlipperyOar
1981 Springbok 18' Restoration/Renovation
Needing some advice here. My floor will be made from 1/2” plywood that’s going to be sealed and wrapped in marine vinyl. Under the floor...
Yesterday at 5:36 PM
M
Mc Tool
If it helps your diagnosis , I think your motor has a "waisted spark " ignition . One coil with two leads.....the coil fires twice per...
Yesterday at 5:32 PM
S
samrcho
reacted to
redneck joe's post
in the thread
How much is it worth?
with
Like
It is worth what you are willing to pay for it. 20 year old boat is 95% going to have hidden issues especially if it has been moored in...
Yesterday at 5:24 PM
R
The charge coil on the timer base fires both cylinders.--And the sensor coil on the timer base fires both cylinders.
Yesterday at 5:13 PM
S
sbs_59
It's a 115 hp Yamaha, not sure about output. From what I've gathered, the main engine wouldn't have long enough run times to utilize an...
Yesterday at 5:06 PM
S
SeanT7
reacted to
nola mike's post
in the thread
Mercruiser 165 shifter cable thread repair
with
Like
Yes, permatex aviation. Don't use silicone anywhere on a boat (mostly, maybe on trim).
Yesterday at 4:42 PM
J
JonBoat55
Alpha1Gen2 gear oil leak
I think I may have found the problem. Used my finger to gently feel first, used the screwdriver for the video. Upper oil seal kit and...
Yesterday at 4:37 PM
R
rhays001
posted the thread
Yamaha 115 oil tank alarm
in
Yamaha & Suzuki Outboards
I need some help with a yamaha 115 115TLRA It has a oil tank on motor and a reserve in the boat, Alarm sounds and goes in limp...
Yesterday at 4:16 PM
R
rogerlamb123
Which kicker mount to install?
If I cant get underneath the stern to provide a support what do you think about a mount like this where it also mounts to the rear of...
Yesterday at 4:06 PM
flashback
reacted to
Scott Danforth's post
in the thread
removing a pontoon off the trailer on land
with
Like
still dont know why the tractor isnt moving dirt
Yesterday at 3:43 PM
flashback
reacted to
DeepCMark58A's post
in the thread
with
Like
Wait you have a private pit big enough for a pontoon? build a ramp. Private pit with no regulations, build a ramp get some rip rap make...
flashback
reacted to
Mc Tool's post
in the thread
Is there such a thing as peeing too hard?
with
Like
I think its one of them things where you dont realise how bad things had got untill you fix it .......Im talking about the outboard 😆...
Yesterday at 3:41 PM
