S
stevh1155
reacted to
Chris1956's post
in the thread
Replacing water pump impeller for first time
with
Like
Glad it worked out. Next time will be easier..... On those IL6 motors, keep the fuel fresh and the waterpump in good shape and don't...
Jun 4, 2026
dingbat
reacted to
redneck joe's post
in the thread
Random
with
Like
Jun 4, 2026
dingbat
replied to the thread
Random
Sissies.....one of their drivers refuses to pull in the driveway if the dog is outside. Throws packages from inside the truck towards...
Jun 4, 2026
M
MikeSchinlaub
Bimini Top Hold Down Bracket is loose, need fix
Sometimes being a short guy helps, og course then I have a hard time reaching stuff once I get squirrled into a tight spot. Haven't...
Jun 4, 2026
M
MikeSchinlaub
reacted to
Scott Danforth's post
in the thread
with
Like
most of the deck hardware is bolted on BEFORE the cap goes on the boat. you will most likely need to cut an access hole for a quick fix...
Jun 4, 2026
southkogs
Anyone want to live at sea full time?
LOL ... the reality ...
Jun 4, 2026
dingbat
reacted to
MikeSchinlaub's post
in the thread
How much deflection is normal in Fiberglass Deck
with
Like
Hey, I took it in stride, no offence here. I know my shortcomings, and calling witchcraft was a joke based on them.
Jun 4, 2026
Jun 4, 2026
R
ricodudink
Water or oil in Cylinders
I am currently pressure testing it at 15 psi. Over 15 minutes, I lost about 12 mbar (approximately 0.17 psi). I suspect this is due to...
Jun 4, 2026
FLATHEAD
No Thanks!!
Jun 4, 2026
FLATHEAD
reacted to
in the thread
with
Like
sounds Orwellian dystopia meets Elysium meets the movie passengers....... we could put the Bezos and Musks of the world on it and hope...
Jun 4, 2026
dingbat
Bypass oil injection 2000 90ELPTO
Very, very old news. The problematic OMC VRO system was replaced in 1986 with the current version. Very reliable...been using mine...
Jun 4, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
It's going . . . :LOL: The bottom seam is all filled in and glassed, and the entire pod is sanded in preparation for fairing compound...
Jun 4, 2026
FLATHEAD
reacted to
tpenfield's post
in the thread
with
Like
Mercruisers are sold !!! . :cool: The Admiral is happy to have some garage space back.
Jun 4, 2026
FLATHEAD
reacted to
tpenfield's post
in the thread
with
Like
Last bit of grinding . . . prepping the scarf joint on the hull bottom. . . .
Jun 4, 2026
