jimmbo
replied to the thread
115 6c TOP piston cylinder issue
The Hose provided a Vacuum Draw on the Fuel Bowl during part throttle operation, resulting in Less than Atmospheric Pressure on the Fuel...
Jun 4, 2026
L
lintmann
posted the thread
Speedometer Not Working
in
Mercury MerCruiser Sterndrives & Engines
This boat is I believe a 99, regardless its an Alpha 1, Gen 2 drive. I've just replaced the bellows and water supply hose and was about...
Jun 4, 2026
I
ianmoore
That is interesting! i never knew what those little hoses were for. I figured it was part of some deep black art I wasn't meant to know...
Jun 4, 2026
Z
zealer
posted the thread
Groove on Input Shaft Stopping from Passing through Gimbal
in
Volvo Penta I/O & Inboard Gas Engines & Outdrives
Hi, Trying to re-install my drive after changing the gimbal and it has been a nightmare. The alignment tool goes in easily, spline marks...
Jun 4, 2026
Seasons Recreational
Aluminum transom has had heat distortion
Hey guys, so there’s the fix I went with. I think StagJet did a great job on a challenging fix. I decided I didn’t want to cut of any of...
Jun 4, 2026
ab59
Thinking about selling my 90hp 1986 Mercury inline 6
thanks for your replies. I was hoping to get 2000 for the motor and all the parts. Don't know now though. Almost makes me wish that I...
Jun 4, 2026
guy48065
Very short dock lines
If I ever see whips in use on my lake I'll have a look and see how well they work with a pontoon.
Jun 4, 2026
dwco5051
Anyone want to live at sea full time?
Been there. More rules than a HOA too.
Jun 4, 2026
J
Jeff J
Splicing two 1” square Bimini tubes
I agree. Inner sleeve and attach with your favorite method. We had one break. I thought the welder would sleeve it but he just did a...
Jun 4, 2026
A
airshot
Water or oil in Cylinders
Have you run a compression test on all 4 cylinders ? What was the read ?
Jun 4, 2026
dingbat
https://www.outwater.com/F500-PARENT?quantity=1&finish=2311
Jun 4, 2026
redneck joe
reacted to
MikeSchinlaub's post
in the thread
Boats from work.
with
Like
Sealer. Painted. Reducing the photo size did some wonky things to the walls.
Jun 4, 2026
redneck joe
reacted to
dingbat's post
in the thread
Random
with
Like
Sissies.....one of their drivers refuses to pull in the driveway if the dog is outside. Throws packages from inside the truck towards...
Jun 4, 2026
It's normally just a section of smaller square tube. For example on 1-1/4" 1/8 wall, a section of 1" square tube is used as the...
Jun 4, 2026
jimmbo
Cylinders 1&2 share a Carb, 3&4 share another, and 5&6 share the last one. A leaky upper Crankshaft Seal can result in #1 running Lean...
Jun 4, 2026
