FLATHEAD
reacted to
warddog's post
in the thread
removing a pontoon off the trailer on land
with
Like
Forgot to update all you good folks that have offered ideas. I backed the trailer right down into the pit on the rocks and unloaded the...
Jun 5, 2026
C
ChooChooSnakeMan
replied to the thread
Bimini Top Hold Down Bracket is loose, need fix
Thanks Scott, Sometimes I do overthink things and / or am to cautious. I will check to see if the back rest cushion can be removed. If...
Jun 5, 2026
E
Earl Cordova
Speedometer Not Working
On mine the pitot hole in the front of the lower drive got plugged. The mechanic at the dealership told me to go buy a 1/8" x 12" drill...
Jun 5, 2026
D
DeepCMark58A
Or you could get an app on your phone, cheap and easy.
Jun 5, 2026
D
DeepCMark58A
reacted to
warddog's post
in the thread
with
Like
Jun 5, 2026
A
airshot
reacted to
kenny nunez's post
in the thread
with
Like
The hose between the drive and the speedometer may have been rodent food. That happened on a boat I bought that had been laid up for...
Jun 5, 2026
A
airshot
Find a different speedo, those pressure units are very inaccurate below 20 mph. Replace the Speedo with a more useful gage to fill the...
Jun 5, 2026
W
warddog
Jun 5, 2026
K
kenny nunez
Jun 5, 2026
C
clupe000
reacted to
alldodge's post
in the thread
First boat
with
Like
Looks like member Jimmbo has your motor linked in post 3 Parts 31 and 32
Jun 5, 2026
A
airshot
Thinking about selling my 90hp 1986 Mercury inline 6
In my area ( lake erie) it might bring 1500 tops with all the paperwork if it looks really good !
Jun 5, 2026
A
airshot
reacted to
jimmbo's post
in the thread
with
Like
It is worth, whatever somebody is willing to give you for it, and that will likely vary from person to person. If you have the Receipts...
Jun 5, 2026
I
ianmoore
115 6c TOP piston cylinder issue
Thanks for the additional details on what it does. Ive got a lot of work to do, but will do this after i go through the carbs
Jun 5, 2026
reacted to
alldodge's post
in the thread
Oil pressure switch / oil pressure sender
with
Like
The GL series motors use switches to apply a ground to turn ON the alarm, they have nothing to do with spark or fuel Your motor uses a...
Jun 5, 2026
Robalo2440 1995 Nav light needs repaired
Helps to cut out the middle. Attwood buys that light along with sea-dog, perko, etc., and its stainless. the OP's light is just an...
Jun 5, 2026
