Kwanza
replied to the thread
Oil pressure switch / oil pressure sender
Thank you. Another couple of images of the engine attached. Yes, that's the only place I have hose/tube coming from to the carburetor...
Jun 6, 2026
Kwanza
reacted to
Fun Times's post
in the thread
with
Like
You have a mechanical fuel pump... It's the one with the yellowish hose running to it / to the left of the white oil filter. How about...
Jun 6, 2026
Fun Times
Tilt / Trim 50A CB - 2001 GXi-A ... where to look?
While there's circuit breakers mounted on the engine of the 50-amp range for engine items, in looking at some parts catalogs it appears...
Jun 6, 2026
Fun Times
Holley carb gaskets - correct part #??
Your VP part number looks to be 21533400...
Jun 5, 2026
L
lintmann
Speedometer Not Working
Thanks guys, call me crazy but I prefer the equipment on my vehicles to work as they should, a dead gauge bugs the hell out of me. The...
Jun 5, 2026
flyingscott
Check Timing Joe Reeves method question. 200hp Johnson
1100 rpm on muffs is normal
Jun 5, 2026
Fun Times
Jun 5, 2026
Kwanza
reacted to
Fun Times's post
in the thread
with
Like
That carburetor appears very dirty and corroded possibly indicating water at some point got in there... Might be time for a carb tear...
Jun 5, 2026
Kwanza
reacted to
Fun Times's post
in the thread
with
Like
Disconnect the connector wire B in your photo as that should stop the horn....Or find the horn under/behind the helm/dash area and...
Jun 5, 2026
Kwanza
reacted to
alldodge's post
in the thread
with
Like
The GL series motors use switches to apply a ground to turn ON the alarm, they have nothing to do with spark or fuel Your motor uses a...
Jun 5, 2026
Kwanza
reacted to
Scott Danforth's post
in the thread
with
Like
A is your gauge sender. It only controls the gauge B is the wire off the oil switch C is the oil fitting for the oil switch The...
Jun 5, 2026
Kwanza
Thank you. That indeed stopped the alarm, and I can now listen when I turn key from OFF to ON. I can hear a single faint click from...
Jun 5, 2026
redneck joe
posted the thread
electricians? Breakers, GFCI, AFCI
in
Dockside Chat
Our 'new house' is a 79 model rancher. Fancy for the day and it has a 20x22 shed that used to have power for lighting and HVAC.. No...
Jun 5, 2026
Fun Times
Jun 5, 2026
Fun Times
Jun 5, 2026
