redneck joe
reacted to
Mc Tool's post
in the thread
Thinking about selling my 90hp 1986 Mercury inline 6
with
Like
Well if fuel was 4 bucks a gallon Id def keep the 2 stroke . Right now fuel is $3.50nz ish a LITRE for med octane ( cant think who's...
Jun 7, 2026
FLATHEAD
replied to the thread
Aluminum transom has had heat distortion
Looks good
Jun 7, 2026
M
Mc Tool
Yeah, I didnt really buy it at the time .....turns out the guy couldnt lie straight in bed ...we dont associate any more 🙂
Jun 7, 2026
R
That belt on the inline models was the same from about 1954 to 1980.----Should not be hard to find one.
Jun 7, 2026
R
Evinrude 40 hp trim removal
Does the lower tilt pin only come out in one direction ?
Jun 7, 2026
C
carlos515
Dual battery or booster pack?
Thanks everyone for your help and input. I have finished the dual battery project, along with my audio system upgrade.
Jun 7, 2026
C
carlos515
reacted to
boscoe99's post
in the thread
with
Like
As a side comment, I would say that if the starting battery failed to do its job of cranking the motor I would not parallel (combine)...
Jun 7, 2026
S
saltchuckmatt
Not really sure of how you would "Cut it away" but possibly. I would think doing it the way I describe wouldn't take and longer...at...
Jun 6, 2026
Seasons Recreational
Still need to paint the back end, but was able to slip the coosa under the new enforcement.
Jun 6, 2026
M
Mc Tool
Jun 6, 2026
L
lazywater
Has anyone had any experience with Attwood Integrated Fuel Demand Valve
did you resolve your issue? i have the same boat with the same valve, attwood part 99IFDV00-1. ai claims it can fail and starve fuel...
Jun 6, 2026
A
airshot
Mercury 850 85hp. Good engine or stay away?
Test holes are drilled on the inside and do not go thru, just deep enough to get into the wood skeleton....if the chips are wet and dark...
Jun 6, 2026
A
airshot
I considered getting a new 40 ho four stroke to replace my like new older two stroke. Compared the mfgr claims on fuel economy for...
Jun 6, 2026
M
maineiac5586
I really dont want to spend any more time trying to save it. I just want it removed so I can list it on ebay. Will cutting away those...
Jun 6, 2026
CLi87
Water coming out of bottom of engine area?
Yea I'm planning to pull the engine, was just trying to see if anyone had run into this problem before.
Jun 6, 2026
