P
Pmt133
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
Today was supposed to be a rainy day according to the weather forecasts. So, I planned to do the electrical work, given that the boat...
Jun 7, 2026
replied to the thread
Bimini Top Hold Down Bracket is loose, need fix
Most likely the backing plate was wood and it rotted I wouldn't use a riv-nut to hold anything other than upholstery to fiberglass
Jun 7, 2026
Outdrive up or down?
Stringers get towed up
Jun 7, 2026
flashback
reacted to
tpenfield's post
in the thread
with
Like
Jun 7, 2026
tpenfield
Jun 7, 2026
9
99yam40
Crank seal issue?
I would make sure the spark timing is in spec and that it advances in spec also, by using a timing light. If a cylinder is not burning...
Jun 7, 2026
Dual battery or booster pack?
If combined for a few seconds it will increase the current and also the better Bat will be able provide more voltage, which is normally...
Jun 7, 2026
redneck joe
reacted to
tphoyt's post
in the thread
Aluminum transom has had heat distortion
with
Like
Looks like a solid fix. Glad you got it all sorted out and don’t have to always wonder what’s going to happen.
Jun 7, 2026
nola mike
1998 Mercruiser 4.3 Tick/Knock
So hard to diagnose sounds over the internet First, have you done any maintenance on the boat? Oil change, gear oil, pull the drive...
Jun 7, 2026
P
Pmt133
reacted to
Scott Danforth's post
in the thread
Early 2000's Rinker
with
Like
Some light reading https://forums.iboats.com/threads/perspective-of-fiberglass-boat-design-life.683703/
Jun 7, 2026
W
Willyclay
Welcome to the forum! The members here are great and should be able to help you fix your problem. I will just tag-along and try to...
Jun 7, 2026
K
kenny nunez
I Think they came from the factory with water.
Jun 7, 2026
T
tphoyt
Jun 7, 2026
Fuel system issues
Problems filling are either an obstruction in the fill line, or a blockage in the vent line
Jun 7, 2026
Early 2000's Rinker
Jun 7, 2026
