beckoning
replied to the thread
2004 Yamaha 150hp oil sensor light
Thank you 99Yam and boscoe99. Starting with motor tilted up caused the low oil pressure sensor to light up, and STAY ON!! Finally...
Jun 8, 2026
K
Kosmofreeze
Tilt / Trim 50A CB - 2001 GXi-A ... where to look?
I'll go as far as saying that the DESIGN is simple. The problem with my installation is the way it is IMPLEMENTED. I still haven't...
Jun 8, 2026
redneck joe
Outdrive up or down?
always store down and trailering lowered will result in damage
Jun 8, 2026
ratdude747
Mercruiser 888 Unexpected Prop behavior?
Turns out Piranha doesn't make a 20 pitch blade... so looks like 21 was the correct pitch for running light. Yeah, it was a bit low on...
Jun 8, 2026
I/O (Sterndrive) Conversion to Outboards
Ted, did you pull the fuse for the trim tab pump? would hate for you to bump the switch and spray ATF into the fresh bilge
Jun 8, 2026
JonBoat55
reacted to
Scott Danforth's post
in the thread
Perspective of Fiberglass Boat design life
with
Like
Having been a member on this wonderful forum for a few years, I thought I would share some perspectives Design Life..... that magic...
Jun 8, 2026
Help. Transmission oil? 1987 Merc 7.4L GM-454 V-8 ?
back in 1987, every fluid on your boat would most likely be SAE 30. it will be in the steering system, the trim tabs, the motors, and...
Jun 8, 2026
nola mike
reacted to
jimmbo's post
in the thread
Thinking about selling my 90hp 1986 Mercury inline 6
with
Like
I would rather own an Engine with a Carb, than one with the Impossible to troubleshoot, adjust, or repair Fuel Injection
Jun 8, 2026
J
Jeff J
Fuel system issues
Checking the vent would be good. Was the vent check valve working when you pulled it? It may also be that you had just the right angle...
Jun 8, 2026
Grub54891
Yes. There should be a tag on top of the v-drive stating the brand, possibly velvet drive or the like.
Jun 8, 2026
Grub54891
reacted to
in the thread
with
Like
Non detergent SAE 30
Jun 8, 2026
Grub54891
reacted to
Mc Tool's post
in the thread
Random
with
Like
This is random .,.screenshot of notifications How can past tense be going to happen tomorrow .........think about it 😁
Jun 8, 2026
Grub54891
reacted to
redneck joe's post
in the thread
Random
with
Like
A twofer https://www.facebook.com/share/r/1CTdsTDYfh/
Jun 8, 2026
redneck joe
Random
Yeah, i always ask my kiwi friend what the day has instore for me. After 20 years he still laughs...
Jun 8, 2026
J
Jjohnson1065
Crank seal issue?
Yes, i put new plugs in every spring. When i pull the spark plug wires off the bottom two cyls nothinf changes but if i pull the top one...
Jun 8, 2026
