reacted to
DeepCMark58A's post
in the thread
Killing time
with
Like
Chipmunks in the retaining wall, and raccoons digging up every single turtle nest. Have you rodents not learned from the squirrels? I...
Jun 8, 2026
replied to the thread
Mercruiser 454 I Need Help Identifying This Engine
Only way to determine if the motor was rebuilt is to pull it apart and inspect it Measure the bore diameter, the crank journals, etc...
Jun 8, 2026
Look below the distributor on the block deck for the casting number Then see if the number comes up in this link...
Jun 8, 2026
2002 Skeeter ZX225 Windshield
Her you go...
Jun 8, 2026
J
Jjohnson1065
Crank seal issue?
Thanks for the advice. My flywheel has TDC labelled for each cylinder so i stuck a dial gauge in each spark plug hole and found the...
Jun 8, 2026
Grub54891
reacted to
Scott Danforth's post
in the thread
Help. Transmission oil? 1987 Merc 7.4L GM-454 V-8 ?
with
Like
back in 1987, every fluid on your boat would most likely be SAE 30. it will be in the steering system, the trim tabs, the motors, and...
Jun 8, 2026
Grub54891
Lost All Steering on Bravo 3 Outdrive
have been chasing an electrical issue on this boat for almost as long as I have owned it. what style of bilge pump do you have? Those...
Jun 8, 2026
Grub54891
reacted to
tphoyt's post
in the thread
Random
with
Like
We have swimming raft where I work and they get stored for the winter in more protected waters. A few years ago a pair made a nest on...
Jun 8, 2026
First time bellow job Alpha One Gen2
Ayuh,..... You can't go wrong, following the manual,.....
Jun 8, 2026
Mercruiser 888 Unexpected Prop behavior?
Ayuh,..... You don't "Feel" boat motors lugging,... 'n 4200 rpms is lugging a V8,...... Yer more apt to just burn a hole in a...
Jun 8, 2026
J
jws123
I also found 10232427 stamped on the top of the pistons I have no knowledge of this engine if it was ever built ect.
Jun 8, 2026
D
DeepCMark58A
Killing time
Half hour traps out, 1 less.
Jun 8, 2026
J
jws123
posted the thread
in
Mercury MerCruiser Sterndrives & Engines
Well I am back! I bought a speed boat its been a few years since I have owned a boat. The 454 engine in this boat is shot It had water...
Jun 8, 2026
R
rogerlamb123
Can someone send me a picture of the boat capacity plate
Thank you!
Jun 8, 2026
D
DeepCMark58A
posted the thread
Killing time
in
Dockside Chat
Jun 8, 2026
