99yam40
replied to the thread
Crank seal issue?
That looks like #2 is charge coil , #3 is lighting coil #4 (Only one)pulser coil , & #5 is crank position sensor definitely different...
Jun 9, 2026
L
Lloyd R
posted the thread
Mercruiser Coil Wiring
in
Mercury MerCruiser Sterndrives & Engines
I was boating and my 1996 Crownline 7.4 Mercruiser stalled. I tried starting and noticed spark at the top of the coil. I was coming out...
Jun 9, 2026
reacted to
DeepCMark58A's post
in the thread
Killing time
with
Like
Nope no 22 I have a 22 but it is in a closet. My options are 410, 20 gauge, 45 acp or buckshot and brass from the judge. I am going with...
Jun 9, 2026
ratdude747
Mercruiser 888 Unexpected Prop behavior?
Yes. 4200 on the 19 with 4 people is likely too high if running lighter... so that'd make the 21 with two people at 3700 the lesser evil...
Jun 9, 2026
Scott06
1975 Mercruiser Tilt/trim issue
yes. Get a factory manual for your set up you will find it invaluable if drive came up in reverse I would think you have a bad reverse...
Jun 9, 2026
redneck joe
I/O (Sterndrive) Conversion to Outboards
i bet you dont have a mini tabasco in a holster on yours tho...
Jun 9, 2026
R
rogerrabbitis
it does both ?
Jun 9, 2026
How to tighten up rack/pinion slack in steering
Ayuh,..... Odds are, the rack, or pinion gear, or the cable housing is worn,...... The "Fix", is replacement,....
Jun 9, 2026
B
Berkley1
VP 5.7 TBI bogging down
I did check the ASV all good
Jun 9, 2026
reacted to
Lou C's post
in the thread
1999 4.3L...
with
Like
Glad to hear that! Think about that 2 piece conversion we discussed. Long term it’s the way to go.
Jun 9, 2026
reacted to
DanOnTheBoat's post
in the thread
1999 4.3L...
with
Like
Hello @everyone, just wanted to let you guys know boat is great! I think it was condensation... After doing 2 engine flushes, the oil...
Jun 9, 2026
D
DeepCMark58A
Killing time
Funny up here in the country people have a different attitude about vermin and dealing with the situation. 2 hardware stores I stopped...
Jun 9, 2026
Ayuh,..... That, is the reverse-lock, 'n the trim indicator,.....
Jun 9, 2026
D
DeepCMark58A
Killing time
Jun 9, 2026
Lou C
You checked the fuel pick up screen but did you also check the anti-siphon valve? Also, a good way to rule out the engine fuel system...
Jun 9, 2026
