replied to the thread
1971 Silverline Comoro 16.5
You have to pull the motor and drive before going any further Take pictures and measurements of the stringer system Expect to pay $3k...
Jun 10, 2026
Killing time
So you missed it's head?
Jun 10, 2026
F
froggy1150
Outdrive up or down?
I tow mine up without issue. I do put a small c clamp on the arched gear assy where if there were a failure it would wedge in the...
Jun 10, 2026
reacted to
kenny nunez's post
in the thread
with
Like
I Think they came from the factory with water.
Jun 10, 2026
Fun Times
reacted to
Kwanza's post
in the thread
Oil pressure switch / oil pressure sender
with
Like
The mystery deepens. After 5 days of investigations (and no intended fix!) my fuel pump works and engine runs. I've decided this morning...
Jun 9, 2026
Kwanza
Jun 9, 2026
jimmbo
Mercruiser 888 Unexpected Prop behavior?
If the Engine breathes better with changes to the Induction System, it may make more power at a given Rpm as compared to the Stock...
Jun 9, 2026
Kwanza
reacted to
alldodge's post
in the thread
with
Like
As your state the filter is not done correctly. With it connected this way there is no filtering of the fuel and any crud is pump...
Jun 9, 2026
dwco5051
Killing time
Raccoon ballistics test. Dog barking to alert me something is after her chickens. In my bare feet, flashlight in one hand, Beretta 96...
Jun 9, 2026
L
Lloyd R
Mercruiser Coil Wiring
Wow, this makes me pause. I really want to get it back to original. I will have to get that serial number. Hopefully tomorrow...
Jun 9, 2026
i_like_boats
85 Crestliner Nordic floor replacement
So I was reading around Here and I also see that carpet glue is also needed. I was just going to wrap and staple. Would the O.T.F. have...
Jun 9, 2026
J
Jmunk
First time bellow job Alpha One Gen2
My speedometer hose was behind the water hose from the factory, I put it back the same way. I’ve had better luck with the exhaust...
Jun 9, 2026
W
Wrenchstench92
Ok here are some pictures. Make sure you’re sitting down…
Jun 9, 2026
A
Ajstutz69
1972 Terry Bass Boat
Do you still have the boat? Do you have pictures of it? I’m looking to restore one and am having a hard time finding pictures
Jun 9, 2026
K
KGuy
reacted to
Scott Danforth's post
in the thread
How to seal cork valve cover gasket
with
Like
I use copper ultra rtv between valve cover and gasket
Jun 9, 2026
