W
Willyclay
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
I got things on the helm station finished up in preparation for the re-power shop to install the Honda & Optimus stuff. Hopefully...
Jun 11, 2026
ratdude747
replied to the thread
Mercruiser 888 Unexpected Prop behavior?
Good point on the cam grind. Did you mean 1980? My boat is a 1976. And one of the two 888 outdrives I've salvaged came from an early...
Jun 11, 2026
tpenfield
Jun 11, 2026
R
extremely high idle suddenly
Linkage fallen off and timer base not rotating?
Jun 11, 2026
C
I had the throttle stick in my '98 Johnny. The spring which closed the throttle had gotten dirty and stuck the throttle open. You...
Jun 11, 2026
C
Fish finder/bottom map
The size and quality of the screen drives most of the cost of the FF units. You will want the largest display you can afford. The good...
Jun 11, 2026
Scott06
First time bellow job Alpha One Gen2
that is the correct shift cable for a 98 and up Gen 2 just a evolution of parts/ Did it not fit right or work? or just asking because...
Jun 11, 2026
C
Crosbyman
Can anyone help me with removing a flywheel?
morning fog... no threads on the taper but that Dupont SIlicone stuff is amazing sometimes.
Jun 11, 2026
Engine flooded?
Ayuh,...... Welcome Aboard,....... Find, 'n fix the fuel leak 1st,......
Jun 11, 2026
Grub54891
reacted to
redneck joe's post
in the thread
Random
with
Like
https://www.facebook.com/share/r/1DumnMdTj9/
Jun 11, 2026
R
Rurru
posted the thread
Engine flooded?
in
Volvo Penta I/O & Inboard Gas Engines & Outdrives
Hello... Had a bit of a problem with my Volvo Penta 3.0 2008 yesterday. It was running normally on land. I filled it up with gas and...
Jun 11, 2026
JonBoat55
reacted to
Stinnett21's post
in the thread
How to tighten up rack/pinion slack in steering
with
Like
That appears to be the same steering as mine...the back rack system. That amount of play seems normal
Jun 11, 2026
JonBoat55
reacted to
Bondo's post
in the thread
with
Like
Ayuh,...... Sounds like the outer cable sheath has a grove worn in it, allowing the inner(working cable) to move, before it can push/...
Jun 11, 2026
W
Wrenchstench92
1971 Silverline Comoro 16.5
Good morning guys. Ok I understand now, so the cavities between the stringers all get filled with floatation foam? I was under the...
Jun 11, 2026
P
Pmt133
cooking
3 cake 2 raspberry and 2 chocolate. The cake layers are just colored. Same flavor
Jun 11, 2026
