D
DeepCMark58A
replied to the thread
rant
I flew detection fire spotting the last year of my career, when fire weather is active it is a rough ride bouncing around in a little...
Jul 16, 2026
southkogs
reacted to
Pmt133's post
in the thread
Just thought I'd share a nice photo.
with
Like
Pretty good, for a cellphone.
Jul 16, 2026
T
tphoyt
rant
It wasn’t to bad here this morning but the past few hours have changed things. I can’t imagine what it must be like to have to try...
Jul 16, 2026
Ifishmuskie2
Drain gas tank to tell where empty is.
So I had the tank empty by using the fuel line to the engine. So usable fuel. Then I put the new sender in. Then I put 20L in and the...
Jul 16, 2026
D
DeepCMark58A
why I still prefer gauges in my cars
I once cut a flashlight body in my company issued tool box to repair a hose connection to get to a job site to take soil samples.
Jul 16, 2026
D
DeepCMark58A
Random
The size of church bells
Jul 16, 2026
D
DeepCMark58A
I was in Wisconsin dells 5 hours away from home Isuzu pick up water pump was more than dripping but a refills I limped it home, it did...
Jul 16, 2026
1966starcraft18ft
1976 mercruiser 140 carb
The inside of the carb is pitted up real bad and there still white powdery crusty crap in carb I can’t get out of passages but can see...
Jul 16, 2026
Ayuh,....... I don't have an ole carb laying around, 'n sellin' or buyin' ain't allowed in the forums, anyways,....... Others will...
Jul 16, 2026
TwoRivers
1989 70 hp Evinrude Overheating:
If you get an AI response that you know to be incorrect. Respond back that "this motor doesn't have Water Passage Deflectors" or...
Jul 16, 2026
J
Jeff J
Bad idea unless only going a couple of miles. I burned up an engine when I was in my early twenties trying to limp a hose with a pin...
Jul 16, 2026
Merc 250 Verado Fuel increase
Also found out you don't need the special tool to remove or install the ALT belt. 8M0146862 ($55 to $70) Just cut the belt to remove...
Jul 16, 2026
D
DeepCMark58A
rant
Air is better today than the day before without all the warnings. Texted an old friend today, I signed off his task book for crew boss...
Jul 16, 2026
D
DeepCMark58A
S corp different tax code. I refuse to feel guilty about it the private business tax rate once you exceed 50 employees, I will take...
Jul 16, 2026
D
DeepCMark58A
reacted to
redneck joe's post
in the thread
with
Like
well every four years should not be having any issues, regardless.
Jul 16, 2026
