J
jlh3rd
replied to the thread
why I still prefer gauges in my cars
so the pull up to the lake showed my normal indication as when new and before the gauge "told" me there might be an issue. It was the...
Jul 18, 2026
S
ShoalSurvivor
gen 2 or gen 1
https://forums.iboats.com/threads/miscellaneous-mercruiser-information.323278/
Jul 18, 2026
J
jlh3rd
Pontoon Questions: Jacking it up while on trailer? & What's this called?
I would not jack it anything beyond what it takes to raise it and place a support. I can't tell how high you can jack the rear of a...
Jul 18, 2026
jimmbo
1981 Johnson 90 HP overheating, but not all the time
Have you verified that the Overheat Sensor is functioning properly?
Jul 18, 2026
Bt Doctur
gen 2 or gen 1
If there are 4 nuts and bolts on the side its a GEN II just 2 nuts on the side, a nut up front and 2 nuts below the cavitation plate...
Jul 18, 2026
B
boscoe99
Charging/fuel enrichment
Jul 18, 2026
J
JJB61Jon
posted the thread
gen 2 or gen 1
in
Mercury MerCruiser Sterndrives & Engines
Hello, I have a 1991 mercruiser 4.3 alpha 1 and need to know which gen I have. My serial# 0D496768 says gen 1 but it has c-clips on trim...
Jul 18, 2026
Lou C
reacted to
tpenfield's post
in the thread
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
with
Like
It's splashed . . . . . . We launched the boat at about 9:00 am today. It was pretty windy, so not much to do but put the boat on the...
Jul 18, 2026
MNhunter1
New Journey
Jul 18, 2026
ranger335
Yes. Last summer. All seemed to be good. This morning I left them in place. gaskets are cheap though, I can remove them if you think it...
Jul 18, 2026
C
Constant drain of 1 of 2 batteries
Charlie, My battery cable had a nick in the insulation. The nick sat in the salt water, and leaked battery voltage into the water...
Jul 18, 2026
C
Jackplate yes or no
I doubt you will gain any performance with a jackplate. Normally. jackplates are on really fast boats, to get the gearcase out of the...
Jul 18, 2026
L
Lpgc
reacted to
tpenfield's post
in the thread
with
Like
Jul 18, 2026
C
crazy charlie
reacted to
cwella's post
in the thread
5.0 XL Mercruiser possible carb/fuel pressure issue
with
Like
Sounds like it may have flooded. The pressure at the separator isn’t normal for a carb setup, so check for a stuck carb float/needle and...
Jul 18, 2026
Ifishmuskie2
reacted to
tpenfield's post
in the thread
with
Like
Jul 18, 2026
