aspeck
reacted to
FLATHEAD's post
in the thread
Grandkids on the dock
with
Like
Seeing the grandkids catch fish is very enjoyable.
Jul 18, 2026
Evinrude Boater
posted the thread
Prop continuity
in
Mercury MerCruiser Sterndrives & Engines
Is part of the prop behind the splined washer intended to be bare metal for continuity. There's a toothed stainless washer between the...
Jul 18, 2026
Berdink
posted the thread
Does this Belong to a 1994 V4?
in
Johnson & Evinrude Outboards
Does this look like anything that belongs to a 1994 V4? While I was working on my thermostats on my 1994 Johnson 90hp v4, I came across...
Jul 18, 2026
replied to the thread
Free Boat
@Captain of the Double G's please read our rules. Do NOT post in a thread more than 90 days old from last post Closed
Jul 18, 2026
K
KD4UPL
Solar chargi g
You absolutely can keep the batteries charged with solar. Reasonably is anyone's guess. I install off grid solar for a living. A six...
Jul 18, 2026
C
Free Boat
Assuming you are referring to a 1969 Pacemaker boat (often called an Alglas), these vessels were built with solid molded fiberglass...
Jul 18, 2026
Berdink
Sputtering Johnson V4 90hp - 1994
I couldn't just step away. I'm so obsessive compulsive. I pulled the thermostats. Again, everything is clean inside. It's obvious the ol...
Jul 18, 2026
Berdink
V4 - Minimize Chances of Broken Rings
So, I could run it until it breaks a ring, but don't I risk when the ring breaks it scouring the cylinder wall, or chipping a portion of...
Jul 18, 2026
C
What is your worst day on the water?
25 foot pacemaker wooden boat ( they measured at the waterline then so back then 30 + ) I was on the flybridge in the state channel (...
Jul 18, 2026
Berdink
reacted to
racerone's post
in the thread
with
Like
I have no idea why the stuck with the bad top ring design for 25 years.----Such an obvious defect.
Jul 18, 2026
R
Jul 18, 2026
C
Double lip/extended lip seal - which way does it install??
The flexible "lips" always are on the pressure side ( think of automotive main seal, oil tries to get out, lips swell and hit...
Jul 18, 2026
T
tphoyt
Random
Been there done that 😂
Jul 18, 2026
C
1965 Pacific Mariner 16'
You found the right wife ! (see the 1st post here please )
Jul 18, 2026
jimmbo
Service manual help
I would suggest you contact Comp Cams, they would be the Best Source. Due to changes in Valve Train Geometry, you may need to use Roller...
Jul 18, 2026
