A
affa
replied to the thread
Exhaust bellow slipped off
Ok thanks, I`ll try to fix it when I take the boat onshore again about a months time
Jul 19, 2026
Berdink
Sputtering Johnson V4 90hp - 1994
Actually, no, it's likely not stuck open. If it was, my primer bulb wouldn't get solid. Nevermind. I'm trying everyone's suggestions...
Jul 19, 2026
B
Bman2895
Mercury 850 85hp. Good engine or stay away?
Well the crappy wiring finally bit me. All I did before it was put some liquid electrical tape on the stuff and let it go. Took it out...
Jul 19, 2026
N
Nordin
Force 2 cylinder throttle cable adustments
The scribed line at the throttle cam is the throttle pick up point. You adjust the throttle pick up point by losing the throttle rod...
Jul 19, 2026
Berdink
Yeah, sorry. If the primer solenoid valve is stuck open and the fuel pump is pumping, the fuel would be just 'pumping' on through the...
Jul 19, 2026
B
brunolund
dp-c shafts and gears still available?
unfortunately i’m aware, and this boat is aluminum. i’ve replaced the wood on this same model once before, as a complete rebuild. I’d be...
Jul 19, 2026
roscoe
Solar chargi g
OK, but why are they run down far enough that they charging. If they are charge when he parks the boat, they should still be charged 6...
Jul 19, 2026
Dukedog
1982 200hp high-performance "Franken-motor" hybrid build serial number 6033659 block casting has the J92W stamp
flywheel is a flywheel no mater for racing and/or stock.. in any case if tha center hub is clocked different than its supposed ta be it...
Jul 19, 2026
T
tphoyt
Blue Star Transom Corner Cap?
If push comes to shove you could look into have one 3D printed.
Jul 19, 2026
Keith7481
Starter electrical connection
I'll check again, thanks. Do you think that would cause it to start with two batteries and only then, start on one battery?
Jul 19, 2026
R
The electric primer is NOT a pump.-----It is a valve.
Jul 19, 2026
Berdink
Since this thread has gotten long, and since it's about possible air/fuel issues, I won't include my ignition troubleshooting here. ...
Jul 19, 2026
R
rbwhiz
1996 Penta 5.0Fi and SX COBRA
I've answered several. Doing that as I'm finding them out. I just answered your question about the fuel pressure. I haven't checked...
Jul 19, 2026
Your not answering any questions asked so good luck, hope you can figure it out
Jul 19, 2026
R
rbwhiz
And I found out this is NOT a GXI. it's a 5.0 Fi. Sooo.. that's been a problem on my end for looking things up
Jul 19, 2026
