dingbat
replied to the thread
Starter electrical connection
Any time I run into possible thermal related situations I start looking at components in the circuit with windings and or contacts. In...
Jul 20, 2026
C
crazy charlie
Constant drain of 1 of 2 batteries
Still searching....still draining down
Jul 20, 2026
its not the key, its a bad power connection giving you fits start at the batteries with a wire brush or 150 grit and shine up every...
Jul 20, 2026
reacted to
alldodge's post
in the thread
with
Like
I see it all as bad connections. Most with this kind of issue they clean a connection or two which is good, but need more clean. Look...
Jul 20, 2026
Blue Star Transom Corner Cap?
there are generic semi-tailored fabricated corner caps that are about $60 per side out there. they take some hammer and dolly work on...
Jul 20, 2026
Keith7481
Power switch was my next check, how about the key itself?
Jul 20, 2026
Great loop speed record attempt
They asked for only those that can help to reply and guess what happened
Jul 20, 2026
redneck joe
if restoring for function, make one otherwise keep looking at it may never happen but at least you can enjoy the hunt.
Jul 20, 2026
Anything is possible with bad connections, the bad connection can be with the switch
Jul 20, 2026
1996 Penta 5.0Fi and SX COBRA
Apologies, don't know why I didn't see fuel pressure, still looking for compression Being a Fi so it's a Ford and your fuel pressure is...
Jul 20, 2026
C
Mercury 850 85hp. Good engine or stay away?
If you left the rectifier (serves as voltage regulator on that motor) unconnected to the battery but connected to the stator, it will blow.
Jul 20, 2026
redneck joe
Random
Jul 20, 2026
acadian2022
1982 200hp high-performance "Franken-motor" hybrid build serial number 6033659 block casting has the J92W stamp
here is a video of my question about advance arm not moving when I manually move the trottle arm
Jul 20, 2026
redneck joe
bad weld https://www.facebook.com/share/p/1Dx6viPcdP/
Jul 20, 2026
ranger335
reacted to
redneck joe's post
in the thread
Hey y'all
with
Like
welcome to the forum
Jul 20, 2026
