nola mike
reacted to
dingbat's post
in the thread
Artificial Intelligence
with
Like
How better to train machine learning modules than to have direct interaction/exchanges with potential "content" providers?
Jul 20, 2026
reacted to
nola mike's post
in the thread
Exhaust bellow slipped off
with
Like
You can. Got one.
Jul 20, 2026
C
replied to the thread
Prop continuity
Continuity between prop and gearcase is a thing. It is not as important with aluminum props as it is with SS. I also installed heavy...
Jul 20, 2026
A
airshot
Solar chargi g
A fully charged battery should maintain that charge for at least a month and while it may drop a little, it should hold enough charge to...
Jul 20, 2026
dingbat
Jul 20, 2026
T
tphoyt
It’s learning how to take over
Jul 20, 2026
A
airshot
Constant drain of 1 of 2 batteries
Does it drain down when disconnected ?
Jul 20, 2026
Dukedog
1982 200hp high-performance "Franken-motor" hybrid build serial number 6033659 block casting has the J92W stamp
also check tha spring that goes between tha two pieces to make sure its intact and installed with tha two tangs inserted correctly...
Jul 20, 2026
C
Mercury 850 85hp. Good engine or stay away?
You can remove the 8 5/16" bolts around the flywheel nut and the flex plate will come off. The stator will also come off. Mark the...
Jul 20, 2026
nola mike
IDK. All over the facebook groups as well posting questions...
Jul 20, 2026
M
MikeSchinlaub
reacted to
redneck joe's post
in the thread
Random
with
Like
Jul 20, 2026
redneck joe
so, what would be the purpose of a bot, here on this site, be? We have no social info, no financial, not monetized, etc?
Jul 20, 2026
nola mike
You can. Got one.
Jul 20, 2026
nola mike
Interesting. Thought there were AI responses and bad information, but didn't think it was a bot.
Jul 20, 2026
Texasmark
How To Remove This Prop Help Needed
Impact tool time. Works when nothing else does.
Jul 20, 2026
