redneck joe
replied to the thread
daily music fix
https://www.facebook.com/share/v/1H1m4jhWx2/
Jul 20, 2026
1997 5.7L thunderbolt ignition. Slow crank
All SBC motors after 1985 have a 1-piece RMS crank Nothing really special about vortec other than the combustion chamber and the roller...
Jul 20, 2026
nola mike
reacted to
tpenfield's post
in the thread
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
with
Like
I had the boat out today for some more break-in running. I was not able to do too much, because one of the trim tabs was in the full...
Jul 20, 2026
F
findinghomer
reacted to
Scott Danforth's post
in the thread
with
Like
That is a vortec 2-barrel manifold in the pic 8 vertical manifold bolts = vortec Non vortec manifolds have 12 bolts
Jul 20, 2026
reacted to
tpenfield's post
in the thread
with
Like
Jul 20, 2026
F
findinghomer
reacted to
in the thread
with
Like
Post the block casting number and the head casting numbers
Jul 20, 2026
Berdink
Sputtering Johnson V4 90hp - 1994
Okay! I think I, (you guys got it). I now just need to take it to the river and run it around some. . It sounds nice and idles down low...
Jul 20, 2026
Dukedog
1982 200hp high-performance "Franken-motor" hybrid build serial number 6033659 block casting has the J92W stamp
finally found your serial number: Your Mercury serial number 6033659 identifies your engine as a 1982...
Jul 20, 2026
tpenfield
Jul 20, 2026
F
findinghomer
Oh okay, I got you yeah mine had six bolts per side, so if I were to buy that motor my manifold would not work. I would have to buy a...
Jul 20, 2026
Dukedog
Ai has no clue about tha 1st, 2nd and 2.5 style blocks starting and stopping!!!.. it says that first gen started in '76 (true) but also...
Jul 20, 2026
Jul 20, 2026
F
findinghomer
I mean if it means taking it to a machine shop and having to have it machined, I'd rather just add the electric pump if it's not that...
Jul 20, 2026
F
findinghomer
Oh so my intake manifold will NOT work? A I I've read it would just trying to get the right answer. The reason I was asking about the...
Jul 20, 2026
nola mike
Oh, I misunderstood you. Thought you meant that if he went vortec would need an electric pump. Yeah, my 2001 4.3 doesn't have a port...
Jul 20, 2026
