S
ShoalSurvivor
reacted to
airshot's post
in the thread
Stuck oil filter
with
Like
Based on your pic....find a piece of flat stock steel, drill two holes spaced the distance across two of the holes in the housing. Drop...
Jul 20, 2026
jimmbo
replied to the thread
Force 2 cylinder throttle cable adustments
Almost all of, if not all of, the Timing Advance happens before the Carb begins to open. With the Control Cables unhooked, does the...
Jul 20, 2026
L
lintmann
1999 MerCruiser 4.3 Alpha 1 Gen 2 Ignition Type and Timing Question....
So how do I know if I actually have the timing lead properly grounded? Yes you can jump the lead to a ground and it look okay but how...
Jul 20, 2026
metalchewy
Long work day. Will give it a go tomorrow after work.
Jul 20, 2026
E
ejnichol
Really dry around here
Extremely dry here. Had first significant rain in many weeks...1" inch. Amazing how my zoysia lawn greened up within 30 minutes.
Jul 20, 2026
Berdink
posted the thread
Water Leaking Near Exhaust Plate - V4
in
Johnson & Evinrude Outboards
When I rev it up, water sprays from behind the exhaust plate. See pictures. It's also coming out around some of the screws, and appears...
Jul 20, 2026
nola mike
1997 5.7L thunderbolt ignition. Slow crank
Wow, was looking over at michiganmotorz... things have become crazy expensive! 1. I personally wouldn't sweat getting a higher mileage...
Jul 20, 2026
I
icatchfish
1972 evinrude 50hp 2 stroke. Crank no start.
In preparation for needing a power pack. Could I get some advice on where is the best place to purchase and ship to Canada? Evinrude...
Jul 20, 2026
metalchewy
reacted to
Nordin's post
in the thread
with
Like
The scribed line at the throttle cam is the throttle pick up point. You adjust the throttle pick up point by losing the throttle rod...
Jul 20, 2026
Berdink
Sputtering Johnson V4 90hp - 1994
Jul 20, 2026
Evinrude Boater
Prop continuity
Should I have bare aluminum on the hub to be in contact with the toothed washer?
Jul 20, 2026
K
KD4UPL
Solar chargi g
I would for this application. I wouldn't sell one to a customer for a new installation. I've helped broker some deals where a homeowner...
Jul 20, 2026
J
JPTL
posted the thread
2000 Optimax 150s both overheating after spark plugs change. Need help
in
Mercury & Mariner Outboards
Original OptiMax,150s on my Whaler Conquest. 415 hrs. Ran fine last season. This season I decided to change the plugs. I went for...
Jul 20, 2026
texsun
posted the thread
No Reverse or Neutral....just Forward VP
in
Volvo Penta I/O & Inboard Gas Engines & Outdrives
I have a 2005 Larson 208 with about 350hrs. My shifter has been rough for a while...last weekend the shifter stopped working. It...
Jul 20, 2026
Stinnett21
Great loop speed record attempt
Refresh my memory on this whole enterprise, is he trying to set the great loop speed record overall or the great loop Jon boat record?
Jul 20, 2026
