C
replied to the thread
Prop continuity
The toothy washer is supposed to dig into the prop hub, thru the paint. You could check it with an ohmmeter to see if you have continuity.
Jul 21, 2026
C
No Reverse or Neutral....just Forward VP
MerCruiser?
Jul 21, 2026
R
Water Leaking Near Exhaust Plate - V4
Not hard to do.-----There are 2 gaskets there.
Jul 21, 2026
R
1972 evinrude 50hp 2 stroke. Crank no start.
Try----evinrudeparts.ca----Good people.
Jul 21, 2026
roscoe
I just got an older @
https://portabote.com/wp-content/uploads/2023/05/portabote_transom.pdf Have googled or GROK-ed for instructions? Lots of u tube videos
Jul 21, 2026
Scott06
Engine misfires after rain storm
No that why he suggested to replace. Typical symptom of misfire when wet is bad cap rotor and wires. If you don’t know when they were...
Jul 21, 2026
Scott06
1999 MerCruiser 4.3 Alpha 1 Gen 2 Ignition Type and Timing Question....
Yes that is a TBV without a Knock sensor. yet to see a knock sensor on a 2 bbl engine. Knock sensors will have a knock module piggy...
Jul 21, 2026
reacted to
Scott Danforth's post
in the thread
stripped SX-A (3L VP) dipstick threads
with
Like
3/8-16 Thread-sert
Jul 21, 2026
acadian2022
1982 200hp high-performance "Franken-motor" hybrid build serial number 6033659 block casting has the J92W stamp
Thank you so much for your time on this.... last year needed parts and a local mercury repair and sale store looked up that serial...
Jul 21, 2026
M
Mc Tool
Sometimes cropping them down a bit will get them under the max size 🙂
Jul 21, 2026
J
Jorge922
I tried to up load some but the files were too large so I need to figure out how to make them smaller. I will get some here, soon...
Jul 21, 2026
F
froggy1150
Better solution for this "seat"
1.If it is stout just bolt a seat on it with whatever size spacer you require. 2. Ifin it is flimsy..... stiffen it up... then step 1.
Jul 20, 2026
S
ShoalSurvivor
reacted to
airshot's post
in the thread
Stuck oil filter
with
Like
Based on your pic....find a piece of flat stock steel, drill two holes spaced the distance across two of the holes in the housing. Drop...
Jul 20, 2026
jimmbo
Force 2 cylinder throttle cable adustments
Almost all of, if not all of, the Timing Advance happens before the Carb begins to open. With the Control Cables unhooked, does the...
Jul 20, 2026
L
lintmann
So how do I know if I actually have the timing lead properly grounded? Yes you can jump the lead to a ground and it look okay but how...
Jul 20, 2026
