flashback
reacted to
tpenfield's post
in the thread
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
with
Like
I had the boat out today for some more break-in running. I was not able to do too much, because one of the trim tabs was in the full...
Jul 21, 2026
nola mike
replied to the thread
1997 5.7L thunderbolt ignition. Slow crank
As mentioned you didn't need to mess with a cam. You need a marine fuel pump. Then yes just switch your stuff over. Wiring will be a...
Jul 21, 2026
flashback
Quiet is good. 😀
Jul 21, 2026
flashback
reacted to
alldodge's post
in the thread
with
Like
No roar, Honda's are quite ;)
Jul 21, 2026
nola mike
Constant drain of 1 of 2 batteries
So no connection between the batteries? What's a parallel switch? And stbd is the draining battery? Seems like an odd setup.
Jul 21, 2026
C
chrisgt
suzuki prop vs turning point 4 blade prop; looking for advise
it depends which one, according to their link here: https://turningpointpropellers.com/_CONTENT/hustler-aluminum-boat-propellers.php...
Jul 21, 2026
Berdink
reacted to
tphoyt's post
in the thread
Water Leaking Near Exhaust Plate - V4
with
Like
Spray the bolts down with your favorite penetrating oil a couple days before your ready to remove them I you have the time.
Jul 21, 2026
Berdink
reacted to
racerone's post
in the thread
with
Like
Not hard to do.-----There are 2 gaskets there.
Jul 21, 2026
L
Lpgc
reacted to
tpenfield's post
in the thread
with
Like
Jul 21, 2026
Horigan
stripped SX-A (3L VP) dipstick threads
The challenge with an insert is getting the a good seal with the O-ring. Oh, and keeping metal debris from entering the drive... I'd...
Jul 21, 2026
F
findinghomer
reacted to
Scott Danforth's post
in the thread
with
Like
truck cams are really really really close to marine cams
Jul 21, 2026
Stinnett21
When I put a Suzuki 90 in their prop wizard it lists the Hustler 4 blade aluminum which I believe is the dual geometry.
Jul 21, 2026
F
findinghomer
reacted to
Scott06's post
in the thread
with
Like
I bought a partial engine from Michigan motorz in 2016. New base engine, intake, carb, ignition , wiring harness and fuel pump. Just...
Jul 21, 2026
G
Gallium
1968 33hp Johnson that Wont Die
Hey, I just wanted to say thank you for including the electrical wiring diagram. I have been searching everywhere. Much appreciated!
Jul 21, 2026
G
Gallium
reacted to
motorstuff's post
in the thread
with
Like
I’m really stumped. I have been working on a boat with a 1968 33hp Johnson. The only issue I have left is that I can’t get the motor to...
Jul 21, 2026
