L
lintmann
replied to the thread
1999 MerCruiser 4.3 Alpha 1 Gen 2 Ignition Type and Timing Question....
Thanks Scott, that helps too. When I'm done I'll check my full advance to make sure I'm close to 24 BTDC and call it a day. Thanks.
Jul 21, 2026
L
lintmann
Oh ya, isn't spell check great lol, It always thinks it know more that you...
Jul 21, 2026
jimmbo
Pontoon Questions: Jacking it up while on trailer? & What's this called?
No Pressure Treated Lumber for the Bunks, as the Chemicals used to treat the Wood, will react with the Pontoons, which are likely Aluminium
Jul 21, 2026
R
1994 Evinrude 120 hp Looper .......cranks, fires, but dies after a second or two
I believe the big looper V-4 uses 140 FT-LBS for the flywheel nut.
Jul 21, 2026
C
Crosbyman
1968 33hp Johnson that Wont Die
6 years later ?
Jul 21, 2026
ezbtr
reacted to
Scott Danforth's post
in the thread
Mechanic tricks?
with
Like
one of the things I did today was use a 5# fist maul and a block of wood. the wood softens the blow so you dont leave marks, the 5#...
Jul 21, 2026
P
Pat_church25
posted the thread
1984 StarCraft SF14 transom bracing question
in
Boat Restoration, Building, and Hull Repair
Looking for some opinions on my idea for bracing my transom. I have a SF14 with a short transom that I converted to a tall transom. At...
Jul 21, 2026
E
elengineerio
Thanks for that info.
Jul 21, 2026
B
brucemustang
Stingray 20' Prop Issue
I’ can’t get my 2007 to plane out of water unless I put someone up in the bow and then it runs fine I went from a 21 pitch to a 17 it...
Jul 21, 2026
J
jlh3rd
I can get under my tandem pontoon bunk trailer and could put a 2x6 across a few ribs . They use these jack screw type support/jacks at...
Jul 21, 2026
B
brunolund
volvo 434a carb base gasket
thank you.
Jul 21, 2026
C
CFB
posted the thread
Pull start won't pull - antique engine
in
Johnson & Evinrude Outboards
Hello, I wasn't very successful searching for info and found this site. Pictures attached on what I have. I bought this 40 years ago...
Jul 21, 2026
You need an isolator gasket for a spread bore carb if your motor has a 4175
Jul 21, 2026
reacted to
Bondo's post
in the thread
1986 Baretta 3.0 mercruiser
with
Like
Ayuh,...... Isolate the block, 'n pressure test it with 'bout 15psi of air,... If the head, or block is cracked, you'll hear it...
Jul 21, 2026
reacted to
kenny nunez's post
in the thread
with
Like
Just remove the hose where it is connected to the manifold. If you do not have compressed air then insert the male end of the garden...
Jul 21, 2026
