D
DeepCMark58A
replied to the thread
Pull start won't pull - antique engine
Shoot transmission fluid into the spark plug hole and let it soak.
Jul 21, 2026
R
1972 evinrude 50hp 2 stroke. Crank no start.
Too far away to walk over for help.
Jul 21, 2026
jimmbo
Pontoon Questions: Jacking it up while on trailer? & What's this called?
That would be the easiest and safest way to do it.
Jul 21, 2026
jimmbo
He is in Saskatchewan.
Jul 21, 2026
R
rbwhiz
1996 Penta 5.0Fi and SX COBRA
Well this has been what my next step is. That's with a clear line going straight into a gas can. But how's the dang thing running? Lol...
Jul 21, 2026
flashback
Still say, cut your new bunks to length, strap them down to the trailer and launch boat, spend a bit of time in the parking lot at...
Jul 21, 2026
SlipperyOar
1981 Springbok 18' Restoration/Renovation
I plan to get new tires for the trailer as these ones are beyond overdue for a replacement, extremely balded lol. I’m not quite sure why...
Jul 21, 2026
SlipperyOar
Two big things done the past few days… Got the few leaky rivets I had sealed up and watertight using Gluv-it. I used a heat gun to...
Jul 21, 2026
R
I think you remove the flywheel by loosening the nut.----No puller required.-----And nothing will jump at you either.
Jul 21, 2026
flashback
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
Never heard of them, how were they, probably a bit troublesome I'd guess.
Jul 21, 2026
flashback
reacted to
racerone's post
in the thread
with
Like
I believe Lauson made a 4 stroke in the late 1940's.
Jul 21, 2026
C
CFB
Thank you for the resource. Correct, I cannot spin the flywheel by hand nor does it budge with a cord. I wasn't sure if I could just...
Jul 21, 2026
R
The ignition does not use 12 volts to make the spark.-----The flywheel must spin fast to energize the ignition system.----Your location?
Jul 21, 2026
Ifishmuskie2
1984 StarCraft SF14 transom bracing question
I like what you have done so far. I would like a panel (either wood or aluminum ) on the outside of the stern to sandwich everything...
Jul 21, 2026
P
Pmt133
reacted to
Scott Danforth's post
in the thread
Need advise on wax cleaner
with
Like
I use 800 grit, followed by Aquabuff 1000, followed by Aquabuff 2000, followed by 3M Finess-It. you have to get thru the oxidized layer...
Jul 21, 2026
