S
saltchuckmatt
replied to the thread
1994 Evinrude 120 hp Looper .......cranks, fires, but dies after a second or two
Just checked the book and I stand corrected. 140 to 150lbs. Hope you have a good strap wrench and a buddy.
Jul 21, 2026
I
icatchfish
1972 evinrude 50hp 2 stroke. Crank no start.
New update (newbies pay attention) DO NOT UNDER ANY CIRCUMSTANCES PLAY WITH YOUR ELECTRONICS UNLESS YOU KNOW WHAT YOU ARE DOING. I...
Jul 21, 2026
F
findinghomer
1997 5.7L thunderbolt ignition. Slow crank
Just found this on market place . Complete L31 5.7 vortec "low miles' , 906 heads, dual plane manifold , 880 block, full hydraulic...
Jul 21, 2026
metalchewy
Force 2 cylinder throttle cable adustments
@jimmbo and @Nordin Thank you both for the additional responses. With the linkage unhooked, yes the moves enough to open past...
Jul 21, 2026
metalchewy
reacted to
jimmbo's post
in the thread
with
Like
Almost all of, if not all of, the Timing Advance happens before the Carb begins to open. With the Control Cables unhooked, does the...
Jul 21, 2026
I
icatchfish
Update: I have found out it's a 20amp inline glass fuse. I have sourced an aftermarket powerpack emp 300-07010, it appears to be the...
Jul 21, 2026
C
Crosbyman
1968 33hp Johnson that Wont Die
how to kill a common old style magneto... with a basic normally open switch... ( service manual clip out of a johnson manual...
Jul 21, 2026
D
DeepCMark58A
rant
Fishing league out on the lake tonight, zero issue with that. Come dark when I hear boat after boat power loading your bass boat pisses...
Jul 21, 2026
IslandExplorer
new project
That's a very good year. Must've run outa AOL cd's, can't load the damn jpg's! 😅 Let's see this maritime time capsule 👀
Jul 21, 2026
IslandExplorer
reacted to
alldodge's post
in the thread
new project
with
Like
Welcome We all like pics, without them it never happened :)
Jul 21, 2026
IslandExplorer
reacted to
Mc Tool's post
in the thread
new project
with
Like
Sure does look like it needs a bit of fixing up .
Jul 21, 2026
IslandExplorer
reacted to
Captain of the Double G's's post
in the thread
new project
with
Like
1974 aluminum
Jul 21, 2026
IslandExplorer
reacted to
sylix_chris's post
in the thread
Post a pic of your starcraft!
with
Like
Jul 21, 2026
flashback
reacted to
jimmbo's post
in the thread
Pontoon Questions: Jacking it up while on trailer? & What's this called?
with
Like
That would be the easiest and safest way to do it.
Jul 21, 2026
P
Pat_church25
1984 StarCraft SF14 transom bracing question
Thank you. I like that idea. Just measured and I could fit a 1/2” piece of plywood in there with shims. Or I could use some scrap 1/8”...
Jul 21, 2026
