Berdink
reacted to
Lukeowski's post
in the thread
1988 Evinrude 90hp idle stalling and link n sync
with
Like
Update 6/28/20 After taking off the carbs to double check everything I found something lodged in the bottom 4th cylinder reed valve!! It...
Jul 21, 2026
Berdink
reacted to
racerone's post
in the thread
carb sync johnson 150...
with
Like
The throttle plates are to be closed at idle.------Therefor they would all pull the same vacuum.-----A carburetor vacuum tool is...
Jul 21, 2026
B
Blue Bomb
replied to the thread
stripped SX-A (3L VP) dipstick threads
I had that happen about 4 years ago. Took it to a local shop at the lake They helicoiled it for 100 bucks.
Jul 21, 2026
S
saltchuckmatt
1994 Evinrude 120 hp Looper .......cranks, fires, but dies after a second or two
Just checked the book and I stand corrected. 140 to 150lbs. Hope you have a good strap wrench and a buddy.
Jul 21, 2026
I
icatchfish
1972 evinrude 50hp 2 stroke. Crank no start.
New update (newbies pay attention) DO NOT UNDER ANY CIRCUMSTANCES PLAY WITH YOUR ELECTRONICS UNLESS YOU KNOW WHAT YOU ARE DOING. I...
Jul 21, 2026
F
findinghomer
1997 5.7L thunderbolt ignition. Slow crank
Just found this on market place . Complete L31 5.7 vortec "low miles' , 906 heads, dual plane manifold , 880 block, full hydraulic...
Jul 21, 2026
metalchewy
Force 2 cylinder throttle cable adustments
@jimmbo and @Nordin Thank you both for the additional responses. With the linkage unhooked, yes the moves enough to open past...
Jul 21, 2026
metalchewy
reacted to
jimmbo's post
in the thread
with
Like
Almost all of, if not all of, the Timing Advance happens before the Carb begins to open. With the Control Cables unhooked, does the...
Jul 21, 2026
I
icatchfish
Update: I have found out it's a 20amp inline glass fuse. I have sourced an aftermarket powerpack emp 300-07010, it appears to be the...
Jul 21, 2026
C
Crosbyman
1968 33hp Johnson that Wont Die
how to kill a common old style magneto... with a basic normally open switch... ( service manual clip out of a johnson manual...
Jul 21, 2026
D
DeepCMark58A
rant
Fishing league out on the lake tonight, zero issue with that. Come dark when I hear boat after boat power loading your bass boat pisses...
Jul 21, 2026
IslandExplorer
new project
That's a very good year. Must've run outa AOL cd's, can't load the damn jpg's! 😅 Let's see this maritime time capsule 👀
Jul 21, 2026
IslandExplorer
reacted to
alldodge's post
in the thread
new project
with
Like
Welcome We all like pics, without them it never happened :)
Jul 21, 2026
IslandExplorer
reacted to
Mc Tool's post
in the thread
new project
with
Like
Sure does look like it needs a bit of fixing up .
Jul 21, 2026
IslandExplorer
reacted to
Captain of the Double G's's post
in the thread
new project
with
Like
1974 aluminum
Jul 21, 2026
