BWR1953
reacted to
aspeck's post
in the thread
Nobody fishing?
with
Like
20 days till my Alaska fishing adventure ... getting excited!
Jul 22, 2026
aspeck
replied to the thread
Nobody fishing?
Jul 22, 2026
No Reverse or Neutral....just Forward VP
Moved
Jul 22, 2026
D
DeepCMark58A
reacted to
BWR1953's post
in the thread
Nobody fishing?
with
Like
My wife and I headed over to the fishin' hole this evening. We haven't been fishing since March. We were definitely overdue. I...
Jul 22, 2026
C
You might ask the mods to move this to the V-P forum.
Jul 22, 2026
reacted to
alldodge's post
in the thread
1986 Baretta 3.0 mercruiser
with
Like
Jul 22, 2026
reacted to
Scott Danforth's post
in the thread
1992 OMC 3.0 Cracked Block
with
Like
first, welcome aboard that block went thru a freeze. the block is busted on the outside where you see it, and on the inside, just...
Jul 22, 2026
metalchewy
reacted to
Nordin's post
in the thread
Force 2 cylinder throttle cable adustments
with
Like
metalchewy, lower cable for timing!!!!!!! The lower cable (your pic in previous post) is the shift cable! The upper cable is for the...
Jul 22, 2026
P
Pmt133
Water in gear oil... (Not a great day)
Swapped the new hib kit in. Will report later. Did wreck the new style tab washer before reaching proper torque though so I swapped back...
Jul 22, 2026
Jul 22, 2026
metalchewy
Agreed. Thanks. I have a hard copy on order and it should be here Friday. Thank You! Ok, will just put the lower linkage back on...
Jul 22, 2026
7
777funk
reacted to
Nordin's post
in the thread
What type of ignition does a 1985 Force 50HP use?
with
Like
Yes, both engines in the pics has battery ignition system. Points and condensers under the flywheel and the ignition coils mounted at...
Jul 22, 2026
metalchewy
reacted to
jimmbo's post
in the thread
with
Like
Okay, now that you have adjusted the Linkages, it is time to get the Official Service Manual for your Engine, and do a Link and Sync to...
Jul 22, 2026
J
Jamz33
Ok thank you. If I air it up. What psi?
Jul 22, 2026
M
MikeSchinlaub
reacted to
alldodge's post
in the thread
Boats from work.
with
Like
That's some nice work
Jul 22, 2026
