N
Nordin
replied to the thread
Force 2 cylinder throttle cable adustments
metalchewy, the dynamic setting has to be under load. If you will adjust the timing in a barrel you have to have a test propeller. Hard...
Jul 22, 2026
Horigan
reacted to
Scott Danforth's post
in the thread
stripped SX-A (3L VP) dipstick threads
with
Like
or pull the cap and take it to your local radiator shop. they will weld it and re-tap it for about $30
Jul 22, 2026
redneck joe
reacted to
aspeck's post
in the thread
Nobody fishing?
with
Like
20 days till my Alaska fishing adventure ... getting excited!
Jul 22, 2026
BWR1953
reacted to
aspeck's post
in the thread
Nobody fishing?
with
Like
Jul 22, 2026
aspeck
Nobody fishing?
Jul 22, 2026
No Reverse or Neutral....just Forward VP
Moved
Jul 22, 2026
D
DeepCMark58A
reacted to
BWR1953's post
in the thread
Nobody fishing?
with
Like
My wife and I headed over to the fishin' hole this evening. We haven't been fishing since March. We were definitely overdue. I...
Jul 22, 2026
C
You might ask the mods to move this to the V-P forum.
Jul 22, 2026
reacted to
alldodge's post
in the thread
1986 Baretta 3.0 mercruiser
with
Like
Jul 22, 2026
reacted to
in the thread
1992 OMC 3.0 Cracked Block
with
Like
first, welcome aboard that block went thru a freeze. the block is busted on the outside where you see it, and on the inside, just...
Jul 22, 2026
metalchewy
reacted to
Nordin's post
in the thread
with
Like
metalchewy, lower cable for timing!!!!!!! The lower cable (your pic in previous post) is the shift cable! The upper cable is for the...
Jul 22, 2026
P
Pmt133
Water in gear oil... (Not a great day)
Swapped the new hib kit in. Will report later. Did wreck the new style tab washer before reaching proper torque though so I swapped back...
Jul 22, 2026
Jul 22, 2026
metalchewy
Agreed. Thanks. I have a hard copy on order and it should be here Friday. Thank You! Ok, will just put the lower linkage back on...
Jul 22, 2026
7
777funk
reacted to
Nordin's post
in the thread
What type of ignition does a 1985 Force 50HP use?
with
Like
Yes, both engines in the pics has battery ignition system. Points and condensers under the flywheel and the ignition coils mounted at...
Jul 22, 2026
