J
Jcgonzal
replied to the thread
1992 OMC 3.0 Cracked Block
Awesome information, thank you! The transom, floor and seats seem to be in great shape, which is the only reason I’m considering...
Jul 22, 2026
88 Capri (2022 SOTY)
1989 omc cobra gear case problem
Not as of yet, still purchasing a few things yet.
Jul 22, 2026
Sorry for the late very late reply, do you have the correct adjustment tools to install the lower shift cable? A possible reason for...
Jul 22, 2026
jimmbo
Help identifying v4 johnson
The jets you mentioned are used in the 84 140hp.
Jul 22, 2026
Scott06
1997 5.7L thunderbolt ignition. Slow crank
100% unless its a rotten transom boat. My buddy just sold his 02 glastron GX185, Fing swim ladder was screwed into transom at water...
Jul 22, 2026
M
macoffman
Help with Safety Chain
Thanks! Would that be strong enough for 3500 lb boat? I'm currently using grade 8 bolts so i'd replace the bolt with one an inch or two...
Jul 22, 2026
M
macoffman
reacted to
Bondo's post
in the thread
with
Like
Ayuh,..... Welcome Aboard,...... a simple way to go would be to use abit longer bolt holding the winch, 'n put a length of chain...
Jul 22, 2026
F
fijimark
posted the thread
Advice on Buying a Jon Boat
in
Boat Topics and Questions (not engine topics)
I'm new to boating and want to get something that I can take my family out on the water with to fish. Since I am new to boating, I don't...
Jul 22, 2026
E
Eddie1920
im looking at the carbs again more in depth this time. i cannot read the size of the main jets however they are quite large visually...
Jul 22, 2026
redneck joe
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
what was original WOT?
Jul 22, 2026
Fishing with Dad
With the rainy season here. going to make new canvas bows for the boat. been meaning to for about 3 years now. getting tired of...
Jul 22, 2026
dingbat
Constant drain of 1 of 2 batteries
Not necessarily. A 12V switch would be all that is required to actuate a remote battery isolation relay. If that is the case, that...
Jul 22, 2026
Jul 22, 2026
C
CFB
Pull start won't pull - antique engine
The old memory kicked in saying I had the gas tank - so I went to the barn loft and there it was. Yeah! As you see, most of the decal...
Jul 22, 2026
J
jlh3rd
and you know it inside and out.
Jul 22, 2026
