redneck joe
replied to the thread
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
and aren't we about a couple five hundred lbs lighter? And newer technology at the powerhead? I know hp is hp but I/o and OB are...
Jul 22, 2026
redneck joe
Nobody fishing?
american alligator and yes, yummy. I've never had off the grill but definately deep fried
Jul 22, 2026
P
Pmt133
Dual props add a lot of drag up top though
Jul 22, 2026
P
Pmt133
reacted to
redneck joe's post
in the thread
Just thought I'd share a nice photo.
with
Like
those are the best days
Jul 22, 2026
M
macoffman
reacted to
Bondo's post
in the thread
Help with Safety Chain
with
Like
Ayuh,...... Plenty of strength in that installation,.... You've already got the winch strap, 'n the ratchet strap,..... you...
Jul 22, 2026
E
elengineerio
1994 Evinrude 120 hp Looper .......cranks, fires, but dies after a second or two
Thanks for that update. To tell the truth 105 was all I could do. But I got a son that can touch it up to 140.
Jul 22, 2026
F
findinghomer
1997 5.7L thunderbolt ignition. Slow crank
Apparently he hasn't done anything to it. Not even removed the heads , so no head gasket change and it has 100,000 mi on it, sounds...
Jul 22, 2026
flashback
He has the same hp. So I'd guess about the same top end. The added length might be a factor. 🤔
Jul 22, 2026
F
findinghomer
reacted to
nola mike's post
in the thread
with
Like
Personally think that if you're going used (rolling the dice) you'd be better off with a truck engine. Even abused, the block has an...
Jul 22, 2026
Jul 22, 2026
flashback
reacted to
Pmt133's post
in the thread
with
Like
First time in a long time I've beached it. Got some lunch.
Jul 22, 2026
reacted to
macoffman's post
in the thread
with
Like
Thanks! Would that be strong enough for 3500 lb boat? I'm currently using grade 8 bolts so i'd replace the bolt with one an inch or two...
Jul 22, 2026
1992 OMC 3.0 Cracked Block
Ayuh,...... Welcome Aboard,...... Are you going to do it, or hire it out,..??
Jul 22, 2026
redneck joe
Jul 22, 2026
redneck joe
reacted to
Mc Tool's post
in the thread
Nobody fishing?
with
Like
What is it ? Obviously some sort of crocodilia, just thinking how it would go on the barbie 🙂
Jul 22, 2026
