P
Pmt133
replied to the thread
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
It was never about the fuel. It's about the journey. At least I keep telling myself that as I laugh filling the tank. :)
Jul 23, 2026
aspeck
reacted to
FLATHEAD's post
in the thread
Trail camera issues fixed, now pics....
with
Like
Bachelor group in my honey hole. 5 bucks possibly 6.
Jul 23, 2026
Scott06
3.0L comparability
the the flywheel size and coupler mounting changed in 1990 when the 3.0 went to a one piece rear seal. so as long as you have a...
Jul 23, 2026
redneck joe
deck waterproofing
yeah only penetrating - same with sealing brick. Nothing surface coat.
Jul 23, 2026
redneck joe
they are about to start not liking each other...
Jul 23, 2026
1966starcraft18ft
posted the thread
3.0L comparability
in
Mercury MerCruiser Sterndrives & Engines
Hey guys, so I’m in search of some compatibility info. As you all know, my sons and I picked up a 1976 Silverline tri-hull boat that’s...
Jul 23, 2026
T
tphoyt
reacted to
Scott Danforth's post
in the thread
with
Like
there is no fuel economy on a boat unless you have sails or oars......
Jul 23, 2026
flashback
deck waterproofing
I like the aussy stuff, don't recall the proper name.
Jul 23, 2026
flashback
Expanding foam (for transom reinforcement) Anyone done this?
It would make sense to calculate the volume of the kickour and pour accordingly. But I've only done foam under a deck which had several...
Jul 23, 2026
dingbat
deck waterproofing
Not sure about brands, but the formulation makes a difference. For long term durability you want a penetrating oil, not...
Jul 23, 2026
Berdink
reacted to
racerone's post
in the thread
What's the difference between QL77JC4 and the QL82C
with
Like
Spark plugs change with fuel burn characteristics.----Fuel is now different than what I remember.----Does not smell the same as it did...
Jul 23, 2026
Scott06
1997 5.7L thunderbolt ignition. Slow crank
check the reviews on rapido seems to be hit or miss there
Jul 23, 2026
reacted to
chknfrmr's post
in the thread
Fuel pump cutting out, 4.3 merc
with
Like
Just to add some closure, it turns out my wiring harness on the fuel pump was bad, causing the fuel pump to cut out intermittently
Jul 23, 2026
flashback
reacted to
in the thread
with
Like
Jul 23, 2026
boatdude100
A "Kickout" I believe are indeed the two "boxes" on either side of the outdrive under swim platform. Has anyone tried to pour 2 part...
Jul 23, 2026
