redneck joe
reacted to
aspeck's post
in the thread
Nobody fishing?
with
Like
We fly into Anchorage and then head to Soldotna on the Kenai river where we will stay for the week. Evenings we will fish the Kenai...
Jul 23, 2026
replied to the thread
Livorsi Wire harness diagram
You will have to call Livorsi
Jul 23, 2026
1966starcraft18ft
3.0L comparability
Sorry. Bore scope, not borehole. Darn fat fingers
Jul 23, 2026
Expanding foam (for transom reinforcement) Anyone done this?
Foam is for flotation until you get to the 8# and 16# density foam
Jul 23, 2026
FLATHEAD
reacted to
aspeck's post
in the thread
Nobody fishing?
with
Like
Jul 23, 2026
N
Nordin
V4 - Minimize Chances of Broken Rings
I have read in prospects for OMC from mid 70.es and they highlights the keystone piston rings helps to rise the pressure from the rings...
Jul 23, 2026
Bugzilla46310
deck waterproofing
Cash in that retirement and go with one of the Trex type of boards. We eliminated our deck and went to a cement patio about 10 years...
Jul 23, 2026
1966starcraft18ft
reacted to
Scott06's post
in the thread
3.0L comparability
with
Like
the the flywheel size and coupler mounting changed in 1990 when the 3.0 went to a one piece rear seal. so as long as you have a...
Jul 23, 2026
1966starcraft18ft
reacted to
nola mike's post
in the thread
3.0L comparability
with
Like
I can't remember offhand the details about input shaft length and older inline MC-1s, but that might come into play at some point...
Jul 23, 2026
1966starcraft18ft
reacted to
Scott06's post
in the thread
3.0L comparability
with
Like
yes that may be true as well, the early inlines (not sure the years) used a shorter input shaft. Unless you have all of it together in...
Jul 23, 2026
1966starcraft18ft
reacted to
Scott06's post
in the thread
3.0L comparability
with
Like
bellhousing likely will fit but coupler will not your old one bolts to crank ub via studs where flywheel attaches. Hub on newer engines...
Jul 23, 2026
P
Pmt133
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
200 is pretty close to what I spent yesterday. :oops:
Jul 23, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
with
Like
I might go to the fuel dock to see how much gasoline I can get for $200 🤣
Jul 23, 2026
N
Nordin
How does my 1997 Force 75hp sound
Yes, sounds good in my opinion too.
Jul 23, 2026
N
Nordin
reacted to
racerone's post
in the thread
with
Like
Sounds perfect.-----Do final mixture adjustment with boat in the water.----In gear and warmed up.
Jul 23, 2026
