redneck joe
replied to the thread
daily music fix
this is kinda fun especially if you are a beatles fan... https://www.facebook.com/share/v/199uXPruSe/
Jul 24, 2026
redneck joe
Restoring childhood boat. A 1972 Ranger. Help needed (pictures).
welcome back
Jul 24, 2026
redneck joe
reacted to
tpenfield's post
in the thread
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
with
Like
I ran the boat up to WOT on a couple of occasions today . . . I probably have not trimmed up enough, as I was only getting 5100 RPM...
Jul 24, 2026
jimmbo
How does my 1997 Force 75hp sound
It sounds Terrible, a complete write-off. Tell you what, ship it to me, no prepaid return shipping required... I will dispose of it for...
Jul 24, 2026
jimmbo
V4 - Minimize Chances of Broken Rings
More realistically, the 17 was prop that was shipped with the Engine. It was often a good choice for boats in the 15-16ft range. Even...
Jul 24, 2026
roscoe
that 75 is a nice motor. Might even push your Jupiter to the moon.
Jul 23, 2026
eggs712
reacted to
tpenfield's post
in the thread
with
Like
It's splashed . . . . . . We launched the boat at about 9:00 am today. It was pretty windy, so not much to do but put the boat on the...
Jul 23, 2026
nola mike
Artificial Intelligence
ok, so real world testing incoming...this is a lot of text, but whatever. My 25 hp merc died suddenly (again). 2 years ago had similar...
Jul 23, 2026
Berdink
reacted to
Scott Danforth's post
in the thread
connecting tach/ determining RPM
with
Like
Get a tiny tach. It has one wire you wrap around a spark plug. Use it as a tool to check your RPMs. Then when your done, put it on...
Jul 23, 2026
Berdink
reacted to
Chris1956's post
in the thread
TACHOMETER ACCURACY
with
Like
Joe Reeves published a timing method for Johnnyrudes, on this forum I believe it did not involve actually running the motor at high RPM...
Jul 23, 2026
Scott06
Mercruiser 5.0 replacement
If it is a vortec long block 96 and newer it is identical to what you have. Good time to drop in a 5.7 which is externally identical...
Jul 23, 2026
nola mike
1997 5.7L thunderbolt ignition. Slow crank
Didn't compare all the specs, but have dealt with MM a few times for tech advice and buying other parts--these guys know their stuff and...
Jul 23, 2026
Scott06
if you haven’t checked out MichIvan motorz worth a look https://michiganmotorz.com/5-7l-vortec-marine-engine-1996-2020/
Jul 23, 2026
Scott06
reacted to
matt167's post
in the thread
3.0L comparability
with
Like
3.0 is commonly cracked externally and able to be patched…. However they are pretty cheap to buy good used.. going up to 1990, is an...
Jul 23, 2026
Berdink
Ha! 😆
Jul 23, 2026
