M
Mc Tool
replied to the thread
Cleaning pitting aluminum
White vinegar , not to strong ...50:50 table vinegar and water ,leave for max 5 mins , bit of a scrub with someone elses toothbrush and...
Jul 24, 2026
M
Mc Tool
1986 Mercury 9.8 110 outboard
Yeah , 100ish psi comp aint brilliant but its enough , decent ⅜" spark, at the right time ,and bit of juice in the plug ole and it...
Jul 24, 2026
reacted to
Bondo's post
in the thread
Mercruiser 5.0 replacement
with
Like
Ayuh,...... Welcome Aboard,....... How did you come to the conclusion that you need a new/ rebuilt long block,..??..??
Jul 24, 2026
With the overheat and a blown head gasket, most likely all you need is a new head gasket
Jul 24, 2026
T
tphoyt
reacted to
tpenfield's post
in the thread
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
with
Like
Mike [Preservati], (Preservati Marine LLC), most likely will be going for ride when he comes out to do the tuning. He used to be at...
Jul 24, 2026
K
Kissdude
I might have the coil wires on wrong. I will figure that out and check
Jul 24, 2026
jimmbo
Good? Spark at the plug at Atmospheric Pressure means nothing. Can it jump a gap of 3/8"?
Jul 24, 2026
K
Kissdude
1980 110(9.8) hp Mercury outboard
Thank you
Jul 24, 2026
R
Green is for #1 cylinder.----Wires with white stripe go to negative.
Jul 24, 2026
C
cjstimpson
Thanks for the link. And for the tips about the carb and prop. I was looking at perhaps getting this one...
Jul 24, 2026
tpenfield
The engines can be moved up a 'bolt-hole' on the clamp mounts . . . not the easiest thing to do though.
Jul 24, 2026
C
cjstimpson
reacted to
Bondo's post
in the thread
with
Like
Jul 24, 2026
C
cjstimpson
A mechanic diagnosed this for me and said a couple cylinders have too little compression. It overheated and I'm guessing the new...
Jul 24, 2026
C
cjstimpson
reacted to
Scott06's post
in the thread
with
Like
If it is a vortec long block 96 and newer it is identical to what you have. Good time to drop in a 5.7 which is externally identical...
Jul 24, 2026
C
cjstimpson
reacted to
nola mike's post
in the thread
with
Like
Might want to check out this thread: https://forums.iboats.com/threads/1997-5-7l-thunderbolt-ignition-slow-crank.781700/
Jul 24, 2026
