K
Kissdude
replied to the thread
1986 Mercury 9.8 110 outboard
no the flywheel key is ok.
Jul 24, 2026
R
If it does not bark with fuel in plug holes , you do not have STRONG spark or spark at the right time.----Flywheel key sheared ?
Jul 24, 2026
Berdink
Water Leaking Near Exhaust Plate - V4
I just finished watching a video on it, and my 90 just takes two of the same gasket.
Jul 24, 2026
K
Kissdude
I have good gap on spark plugs, put fuel down plug holes and nothing happens, doesn't even fire at all. Anything else that I could be...
Jul 24, 2026
nola mike
Can't sync my 2003 25 hp 2 stroke...
I'm not...
Jul 24, 2026
nola mike
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
I forget, why did you want to do the conversion?
Jul 24, 2026
flyingscott
Why are you adjusting the throttle with the shift cable?
Jul 24, 2026
R
ROY WILLIAMS
reacted to
1966starcraft18ft's post
in the thread
3.0L comparability
with
Like
Kinda figured so I’m gonna drain oil and leave drain plug out and then run water through where the thermostat lives and see if any water...
Jul 24, 2026
K
Kissdude
Thanks I will let you know how I make out.
Jul 24, 2026
M
Mc Tool
Cleaning pitting aluminum
Dremel wire wheels do work but the buckin fristles get everywhere , they get stuck in your clothes, migrate from garment to garment in...
Jul 24, 2026
tpenfield
It was about 1-1/2" in total. A balance between 1" per 12" and what made sense from a mounting perspective.
Jul 24, 2026
P
Pmt133
Just out of curiosity... which rule of thumb was used to set the initial AV plate height? I know there were a few options and I'm...
Jul 24, 2026
M
Mc Tool
White vinegar , not to strong ...50:50 table vinegar and water ,leave for max 5 mins , bit of a scrub with someone elses toothbrush and...
Jul 24, 2026
M
Mc Tool
Yeah , 100ish psi comp aint brilliant but its enough , decent ⅜" spark, at the right time ,and bit of juice in the plug ole and it...
Jul 24, 2026
reacted to
Bondo's post
in the thread
Mercruiser 5.0 replacement
with
Like
Ayuh,...... Welcome Aboard,....... How did you come to the conclusion that you need a new/ rebuilt long block,..??..??
Jul 24, 2026
