D
DeepCMark58A
replied to the thread
Flooring ok to reseal/EVA foam?
When I redid the front deck of my pontoon I coated it with fiberglass resin. EVA foam is still sticking 3 summers later.
Jul 25, 2026
dingbat
Tools that younger people would not recognize.
Cleaning out my desk in the basement. My 30 yro kids had no clue what they are
Jul 25, 2026
1992 OMC 3.0 Cracked Block
And forklift motors and trash pump motors. The 3.0 liter starting in 1991 is a built in Mexico industrial motor sold by GM for a bunch...
Jul 25, 2026
R
rowerowe101
posted the thread
in
Boat Topics and Questions (not engine topics)
Hi there, Boat has been sitting for a hot minute, finally got my life together and the engine running in the tank as well, would like...
Jul 25, 2026
Artificial Intelligence
Banks are insured by FDIC for $250k per account per banking establishment.
Jul 25, 2026
dingbat
If your worried about someone seeing you naked, the first thing you do is close the curtains…then you lock the door and put the key in...
Jul 25, 2026
Big Gee
The least expensive route may be to find a cheap donor boat with a usable motor. Just be sure to inspect it thoroghly before buying it.
Jul 25, 2026
1994 Bayliner no spark 3.0L mercruiser
Please re-read the rules you agreed to Regarding your boat, start with following the troubleshooting guide before firing the parts...
Jul 25, 2026
ranger335
Cleaning pitting aluminum
Someone else's toothbrush. That's funny right there.
Jul 25, 2026
VP aq125a/270 overheating issue
Look under the drive where the hose and fitting is on the H-frame. Replace the fitting, pull the drive and replace the O-rings that...
Jul 25, 2026
D
DeepCMark58A
reacted to
tank1949's post
in the thread
Need advise on wax cleaner
with
Like
I may just end up paying for all that elbow grease. Too old....
Jul 25, 2026
ranger335
reacted to
Mc Tool's post
in the thread
with
Like
White vinegar , not to strong ...50:50 table vinegar and water ,leave for max 5 mins , bit of a scrub with someone elses toothbrush and...
Jul 25, 2026
D
DeepCMark58A
1642 vs 1456 Jon Boat. Which is better?
Wider is better.
Jul 25, 2026
How to correct positive camber
Usually trailer axle alignment is adjusted with heat and a brake press by physically bending the axle
Jul 25, 2026
Ifishmuskie2
reacted to
SlipperyOar's post
in the thread
1981 Springbok 18' Restoration/Renovation
with
Like
Got the last big job for this boat restoration done, welded two bungs onto my fuel tank for the pickup and a vent. The existing pickup...
Jul 25, 2026
