replied to the thread
Power steering mount
Replace your mechanic It's not the mount If it's squealing when you turn the wheel, that's a loose belt. Go back to the tensioner
Jul 26, 2026
C
Bass boat trim authority sucks in mid range
Most boats can be trimmed more at higher speed. It is therefore normal for you to use max trim as you approach max speed. At all...
Jul 26, 2026
reacted to
redneck joe's post
in the thread
with
Like
heavy steering and porpoising are two different issues
Jul 26, 2026
reacted to
jimmbo's post
in the thread
with
Like
I suspect you are trimming up too much at the lower speed. The standard mode of operation, is trim out until it start to porporise, then...
Jul 26, 2026
K
Kissdude
1986 Mercury 9.8 110 outboard
If I did miss the pin, I should be able to get it back in without pulling pistons all the way out? I don't want to break another ring as...
Jul 26, 2026
redneck joe
Jul 26, 2026
redneck joe
reacted to
jbcurt00's post
in the thread
Random
with
Like
Bad day to be a boat owner... https://www.facebook.com/share/v/18666Cp3ye/
Jul 26, 2026
FLATHEAD
When you are working on your outboard..............
I couldn’t care less what anyone thinks of my foot wear as well. I just would not wear those. I’ve never worn sandals in my life as well.
Jul 26, 2026
redneck joe
daily music fix
Jul 26, 2026
D
DeepCMark58A
Couple weeks back I changed out filters, I had the engine cover up to check for leaks went to check the gauges then backed up and my...
Jul 26, 2026
BWR1953
Man, that sucks! I'm glad you survived it well enough. As an old guy, I've taken my share of falls, even when I think I'm clear of...
Jul 26, 2026
M
mike_i
downrigger cable & radio question
Does the coast guard actually respond to radio checks on ch 16 other than telling you ch 16 is for hailing and distress only and to take...
Jul 26, 2026
Gizmoray
90 hp elpto bleed system
I was able to reconnect them both. Have had the boat for just over a year, always wondered why the motor always had oil on the one side
Jul 26, 2026
A
airshot
Be Aware of your surroundings.....we all have been there a time or two. Kind of a wakeup call to remind us to pay attention. Don't...
Jul 26, 2026
R
Sorry---Oil injection system has nothing to do with the bleed system----Hurry to a boat shop and have it checked out and installed...
Jul 26, 2026
