redneck joe
replied to the thread
Bass boat trim authority sucks in mid range
yep, thats what i meant to say... :-)
Sunday at 10:40 AM
K
kenny nunez
VP aq125a/270 overheating issue
A good chance the heat exchanger core is either leaking internally or the “O” ring seals are leaking. As SD said the “O: ring that...
Sunday at 10:28 AM
W
Willyclay
reacted to
tpenfield's post
in the thread
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
with
Like
Port engine is counter rotating prop. Starboard engine is standard rotation ( typical for twin OB installations) Honda V8 engine...
Sunday at 10:18 AM
Power steering mount
Replace your mechanic It's not the mount If it's squealing when you turn the wheel, that's a loose belt. Go back to the tensioner
Sunday at 10:09 AM
C
Most boats can be trimmed more at higher speed. It is therefore normal for you to use max trim as you approach max speed. At all...
Sunday at 10:09 AM
reacted to
redneck joe's post
in the thread
with
Like
heavy steering and porpoising are two different issues
Sunday at 10:03 AM
reacted to
jimmbo's post
in the thread
with
Like
I suspect you are trimming up too much at the lower speed. The standard mode of operation, is trim out until it start to porporise, then...
Sunday at 10:03 AM
K
Kissdude
1986 Mercury 9.8 110 outboard
If I did miss the pin, I should be able to get it back in without pulling pistons all the way out? I don't want to break another ring as...
Sunday at 10:01 AM
redneck joe
Sunday at 9:46 AM
redneck joe
reacted to
jbcurt00's post
in the thread
Random
with
Like
Bad day to be a boat owner... https://www.facebook.com/share/v/18666Cp3ye/
Sunday at 9:44 AM
FLATHEAD
When you are working on your outboard..............
I couldn’t care less what anyone thinks of my foot wear as well. I just would not wear those. I’ve never worn sandals in my life as well.
Sunday at 9:42 AM
redneck joe
daily music fix
Sunday at 9:41 AM
D
DeepCMark58A
Couple weeks back I changed out filters, I had the engine cover up to check for leaks went to check the gauges then backed up and my...
Sunday at 9:39 AM
BWR1953
Man, that sucks! I'm glad you survived it well enough. As an old guy, I've taken my share of falls, even when I think I'm clear of...
Sunday at 9:37 AM
M
mike_i
downrigger cable & radio question
Does the coast guard actually respond to radio checks on ch 16 other than telling you ch 16 is for hailing and distress only and to take...
Sunday at 9:29 AM
