redneck joe
replied to the thread
cooking
we just moved 40 minutes away from our local store. Could not find any bacon close to as good - it is just generic bacon. Not a...
Monday at 11:03 AM
redneck joe
reacted to
Bondo's post
in the thread
Bass boat trim authority sucks in mid range
with
Like
Ayuh,..... Put a 6' straight edge along the keel line, from the transom, forward, 'n see whether there's a hook, or a rocker in the...
Monday at 11:00 AM
Lou C
Volvo Penta 5.7 TBI still being a pain
You replaced the anti siphon valve but did you check the tank pick up tube for a screen clogged with gunk? Some have a screen some don't.
Monday at 10:57 AM
C
Heavy steering can also be caused by the motor mounts giving too much, binding up the midsection swivel movement.
Monday at 10:56 AM
Bugzilla46310
reacted to
Seasons Recreational's post
in the thread
Aluminum transom has had heat distortion
with
Like
Have an update on the solution I elected…. After all the welding was done. The back and the inside of the transom was looking pretty...
Monday at 10:47 AM
have you done a compression test? all cylinders near 150 psi?
Monday at 10:15 AM
B
bcj.jones
Very weird Yamaha issue
Come to think of it, the Speedometer sometimes flickers too.
Monday at 10:00 AM
B
bcj.jones
Meaning the Stator is going bad? Or what else would cause low voltage to the CDI? I bought a DVA I can test the stator with. I know this...
Monday at 10:00 AM
D
dypcdiver
Does your boat have the Fuel Vapor Separator tank at the rear of the engine. A couple of years ago I had some bogging and problems with...
Monday at 9:58 AM
FLATHEAD
cooking
I made 5 pounds of venison bacon last fall. Not even close to real bacon.
Monday at 9:47 AM
Cobalt 226 vs 220 or something else..
thats because most marinas have crappy shore power (leaks).
Monday at 9:42 AM
reacted to
Bondo's post
in the thread
with
Like
Monday at 9:40 AM
Monday at 9:34 AM
B
boscoe99
Weird only to those that do not yet know. What you are seeing is indicative of low voltage to the CDI unit.
Monday at 9:21 AM
reacted to
dingbat's post
in the thread
What is this?
with
Like
Switch contacts are not replaceable. You need a new ignition switch. Recommend doing some basic troubleshooting before breaking out...
Monday at 9:16 AM
