reacted to
Cnyncrvr's post
in the thread
AQ130 Wiring Diagram Drawn
with
Like
Yes and thank you for replying. But like I stated in the post, The schematics in the VP manual were not intuitive for the average DIY...
Monday at 11:08 AM
B
bcj.jones
replied to the thread
Very weird Yamaha issue
Also, wouldn't low voltage to the CDI cause running issues as well? Misfires etc. I'm not questioning what you're saying at all. Just...
Monday at 11:08 AM
redneck joe
cooking
i like bacon like i like my women. All kinds...
Monday at 11:04 AM
redneck joe
cooking
we just moved 40 minutes away from our local store. Could not find any bacon close to as good - it is just generic bacon. Not a...
Monday at 11:03 AM
redneck joe
reacted to
Bondo's post
in the thread
Bass boat trim authority sucks in mid range
with
Like
Ayuh,..... Put a 6' straight edge along the keel line, from the transom, forward, 'n see whether there's a hook, or a rocker in the...
Monday at 11:00 AM
Lou C
Volvo Penta 5.7 TBI still being a pain
You replaced the anti siphon valve but did you check the tank pick up tube for a screen clogged with gunk? Some have a screen some don't.
Monday at 10:57 AM
C
Heavy steering can also be caused by the motor mounts giving too much, binding up the midsection swivel movement.
Monday at 10:56 AM
Bugzilla46310
reacted to
Seasons Recreational's post
in the thread
Aluminum transom has had heat distortion
with
Like
Have an update on the solution I elected…. After all the welding was done. The back and the inside of the transom was looking pretty...
Monday at 10:47 AM
have you done a compression test? all cylinders near 150 psi?
Monday at 10:15 AM
B
bcj.jones
Come to think of it, the Speedometer sometimes flickers too.
Monday at 10:00 AM
B
bcj.jones
Meaning the Stator is going bad? Or what else would cause low voltage to the CDI? I bought a DVA I can test the stator with. I know this...
Monday at 10:00 AM
D
dypcdiver
Does your boat have the Fuel Vapor Separator tank at the rear of the engine. A couple of years ago I had some bogging and problems with...
Monday at 9:58 AM
FLATHEAD
cooking
I made 5 pounds of venison bacon last fall. Not even close to real bacon.
Monday at 9:47 AM
Cobalt 226 vs 220 or something else..
thats because most marinas have crappy shore power (leaks).
Monday at 9:42 AM
reacted to
Bondo's post
in the thread
with
Like
Monday at 9:40 AM
