Bt Doctur
replied to the thread
Mercruiser 120 will not shut off constant 12v to coil
disconnect the orange output wire at the back of the alt .If this power is gone the alt is backfeeding
Tuesday at 6:16 AM
J
jlh3rd
Best Deep Cell Marine Batteries
actually...I kinda lied...sort of I use a Duracell and an everstart. The Everstart was my primary battery bought in 2017, when the merc...
Tuesday at 6:07 AM
J
jlh3rd
old pictures
the mint honda 550F, 4stroke, I bought in 1994 for $700 can be worth $10,000 + , according to some sources.
Tuesday at 6:01 AM
T
tphoyt
reacted to
redneck joe's post
in the thread
Random
with
Like
Tuesday at 5:29 AM
T
tphoyt
reacted to
redneck joe's post
in the thread
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
with
Like
god i love my 82 smoker...
Tuesday at 5:28 AM
T
tphoyt
I can’t remember the last time I was on a newer boat.I have never seen independent steering. I guess I’m living under a rock. I just...
Tuesday at 5:28 AM
redneck joe
Tuesday at 5:27 AM
F
findinghomer
1997 5.7L thunderbolt ignition. Slow crank
Yep I am already doing everything myself that's why so many newbie questions because I've never had to install an engine that wasn't...
Tuesday at 5:24 AM
Engine is gas lighting me
No clue
Tuesday at 5:24 AM
T
tphoyt
reacted to
tpenfield's post
in the thread
with
Like
Yes, joystick docking has been around for a while. Each engine has its own steering actuator and 'the computer' figures out steering...
Tuesday at 5:19 AM
F
findinghomer
reacted to
Scott Danforth's post
in the thread
with
Like
Most are marine rated. That style was not used by the OEMs. That is usually used by conversions Vehicle installations may use an...
Tuesday at 5:16 AM
F
findinghomer
reacted to
Scott06's post
in the thread
with
Like
check the reviews on rapido seems to be hit or miss there
Tuesday at 5:16 AM
C
Merc 200hp timming questions.
You can use a caliper or even a steel ruler to set the timing pointer to TDC. I would expect the timing procedure to be the same as any...
Tuesday at 4:55 AM
L
Leedanger
Livorsi Wire harness diagram
Appreciate your help thank you.
Tuesday at 4:42 AM
L
Leedanger
Figured it out and it was indeed the notorious failed diode. I made a video describing the repair in surface level detail just incase it...
Tuesday at 4:41 AM
