J
Jcgonzal
replied to the thread
1992 OMC 3.0 Cracked Block
Thanks everyone, I appreciate the input. The search continues!
Tuesday at 5:23 PM
WIMUSKY
2026 NFL/CFB News and Nonsense
I'm still waiting for the Vikings window to open..... Skol!
Tuesday at 5:11 PM
M
MikeSchinlaub
1981 Springbok 18' Restoration/Renovation
Usually it's flooring first, then foam. You drill some 1 inch holes and pour through, but it looks like you've already wrapped the main...
Tuesday at 5:01 PM
D
DeepCMark58A
Fourwinns doors shut
My uncle had a Liberator back in the day early 90's I loved that boat it was a beast.
Tuesday at 5:00 PM
WIMUSKY
What did u end up buying? Pic?
Tuesday at 4:59 PM
rolmops
reacted to
Captain Caveman's post
in the thread
West Marine going out of business... and I can't think of anything I need!
with
Like
There was/is at least one or two of them. I went to one near Lake Minnetonka probably 10-15 years ago. I seem to remember buying a...
Tuesday at 4:42 PM
F
findinghomer
1997 5.7L thunderbolt ignition. Slow crank
Yeah I wasn't trying to get out of realigning, I was trying to see what would be the best option to get a good starting point rather...
Tuesday at 4:35 PM
B
bcj.jones
Very weird Yamaha issue
Gotcha. So in theory, I could tap into just the yellow, charge wire, to the CDI unit and see if I'm loosing voltage on acceleration...
Tuesday at 4:33 PM
B
bcj.jones
reacted to
boscoe99's post
in the thread
with
Like
The stator has different functions. Coils to charge capacitors in the CDI unit, coils to fire the ignition coils/spark plugs and coils...
Tuesday at 4:31 PM
B
bcj.jones
reacted to
boscoe99's post
in the thread
with
Like
Did you post your problem on another forum? Sounds very familiar.
Tuesday at 4:31 PM
F
findinghomer
In my boat it would actually be easier to pull it from the adjustment nuts especially since I have everything apart. That's why I was...
Tuesday at 4:21 PM
F
findinghomer
Yeah I got you and I totally understand that . I did check my alignment last time I pulled the motor. I just pulled it from the lag...
Tuesday at 4:20 PM
F
findinghomer
reacted to
Scott Danforth's post
in the thread
with
Like
If you sneeze at any of the bolts or simply run the motor. You need to check alignment (annual requirement) If you pull the motor...
Tuesday at 4:18 PM
F
findinghomer
reacted to
Scott06's post
in the thread
with
Like
I did mine by the lag screws as generally they are easier to get to in the boat. You need to do an alignment regardless of marking the...
Tuesday at 4:17 PM
SlipperyOar
Boat is 100% leak free as far as I’m concerned from the hour I had it sitting in the water the other night after rebucking the few...
Tuesday at 3:56 PM
