Scott06
replied to the thread
1997 5.7L thunderbolt ignition. Slow crank
I dont think it matters dealers choice. On my set up the lags were easier to get to with a wobble extension due to a side panel that...
Wednesday at 8:12 AM
Scott06
Engine misfires after rain storm
Not sure on the stator driven set up but this 1974 Evinrude is a coil eater. I went through everything but the coils as I saw spark on...
Wednesday at 8:11 AM
M
MikeSchinlaub
Boats from work.
I would say it's not very common. I've only seen a few of these older styles, and one other that was totally resprayed, yellow and...
Wednesday at 8:09 AM
Lou C
Mercruiser 5.0 replacement
Your cylinders look OK, I'd carefully clean off the old head gaskets, clean up the block deck and measure it. If both sides are good...
Wednesday at 8:08 AM
M
MikeSchinlaub
Lund tyee I/O transom removal
Ok, I get it now. I think I've done one like that a long time ago. The problem withthe rivets is you would have to have them back in...
Wednesday at 8:07 AM
Lou C
if you look close you can see I have a stuck valve like yours, prob due to water in the cyls from blown head gasket.
Wednesday at 8:04 AM
Lou C
I had the same problem on my old 4.3, but it ran fine for 2.5 seasons before getting a bit of water in the front 2 cyls. I checked the...
Wednesday at 8:03 AM
B
Built For Speed
May Day help
Thank you good idea
Wednesday at 7:53 AM
Big Gee
reacted to
racerone's post
in the thread
1992 OMC 3.0 Cracked Block
with
Like
If it " runs " many sellers like you to think that there is nothing wrong with it.
Wednesday at 7:52 AM
Lou C
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
Looks great, I'm still getting used to yellow "ground" wires lol.
B
Built For Speed
reacted to
racerone's post
in the thread
May Day help
with
Like
Test run with a portable tank and hose.
Wednesday at 7:50 AM
R
Help...50hp 4stroke 2003
Well---200 PSI for a 4 stroke ( throttle open ) sounds correct !
Wednesday at 7:41 AM
R
May Day help
Wednesday at 7:19 AM
R
Need HELP identifying motor first
Facr---If flywheel key is sheared the timing light does NOT show that.
Wednesday at 7:18 AM
B
Built For Speed
posted the thread
May Day help
in
Mercury & Mariner Outboards
1987 Mercury Black Max XR2 150 HP (Serial 0A969708) Engine starts immediately and runs great. I replaced the water pump, fuel filter...
Wednesday at 7:15 AM
