  • bruceb58
    bruceb58 replied to the thread How to correct positive camber.
    Buy a new axle. Cheaper than replacing tires.
  • M
    MikeSchinlaub reacted to Bondo's post in the thread Lund tyee I/O transom removal with Like Like.
    Ayuh,..... Way back when I replaced the transom wood in my '74 Starcraft 221 Islander, I cut off a strip of the transom cap, changed...
  • B
    bcj.jones replied to the thread Very weird Yamaha issue.
    Funny thing, I mentioned doing something similar on a different circuit to my buddy but we never did it. I will definitely try that...
  • B
    bcj.jones reacted to 99yam40's post in the thread Very weird Yamaha issue with Like Like.
    I am thinking a bad connection also on the 12 volt circuit +or -
  • B
    bcj.jones reacted to boscoe99's post in the thread Very weird Yamaha issue with Like Like.
    I am thinking that I would disconnect the CDI connector and inspect the terminals, particularly those for the yellow wire. Maybe then...
  • dingbat
    dingbat replied to the thread Ohm specs.
    Ohm testing a coil isn't a reliable means to measure the performance of a coil. I've had more bad coils test good more time than I can...
  • Cup420
    Cup420 replied to the thread Ohm specs.
    Sorry... I need to check the coils
  • Cup420
    Cup420 reacted to mike_i's post in the thread Ohm specs with Like Like.
    "Looking for the ohm and k-ohm specs" specs for what? I'm struggling to understand your question.
  • M
    mike_i replied to the thread Ohm specs.
  • WIMUSKY
    WIMUSKY replied to the thread 2026 NFL/CFB News and Nonsense.
    Idk, probably not? He's only starting his 2nd year on a 5yr contract, not that contracts can't be broken... Couple that with a new...
  • Bondo
    Bondo replied to the thread Lund tyee I/O transom removal.
  • Scott06
    Scott06 replied to the thread Mercruiser 5.0 replacement.
    the new long block I bought in 2016 is just about x2 now. Hard part is if there is a decent machine shop you will be waiting for them...
  • Bondo
    Bondo reacted to MikeSchinlaub's post in the thread Lund tyee I/O transom removal with Like Like.
    Ok, I get it now. I think I've done one like that a long time ago. The problem withthe rivets is you would have to have them back in...
  • D
    Do you think KOC might be on the hot seat if the season does not go well? 4 seasons still no post season win?
  • C
    Chris1956 replied to the thread Mercruiser 5.0 replacement.
    Have you checked the exhaust manifolds for water leaks into the exhaust passages? Also check the manifold to riser joint for leaks past...
